BenjaMia Bakehouse Project
  • #31
    Re: BenjaMia Bakehouse Project
    Jim--
    Does the mortar bag keep the mortar fresh and workable indefinitely, like an icing bag would when making cakes? I love the idea of using the premix and the homebrew for separate applications, but would worry about one drying out while I was fussing with the other.
    Nikki
    • #32
      Hey Jim!
      Just curious... Did you cut a pattern to guide you as you place each course? Or are you using some other method? Ken's string trick worked well for him. Have you come up with something different?
      Anyway. I was just wondering.
      And I'm nosy.
      Dave
      My thread:
      My costs:
      My pics:
      • #33
        So far it's a freestyle build.....doin' what feels right, but I have not reverted to forms.
        I buttressed the bricks on the side of the arch, built the arch and cut the entrance blocks to give a lot of room on the landing. The outer arch is going to be more of a challenge since it's larger. I have to think about what that will look like....maybe buy some new bricks.
        Laid up the next ring of bricks. ...And it is getting more interesting!
        The homebrew is portland based so the mortar bag needs to be cleaned after use.....but it keeps the mortar mix moist while you need it. I use the premix on the inside of the bricks next to the dome and let it set up, then I come in and fill in behind and finish by smearing the mortar on the backside of the dome. I keep it moist and give it a wet brush as well.
        Drake, I have a bag of castable and will try to cast the transition vent to fit the opening I've created.
        I also took a stab at beveling the arch blocks for better exhaust flows.
        so far so good....
        • #34
          another chain....
          • #35
            Arch failure
            Well I broke my new oven arch.. ..my fault for two reasons....
            I didn't shim it well enough and removed the form too early.....the premix mortar in the broken joints was still soft since the masonry mass was so moist!
            Good news is it broke into three blocks....so I reset the end block and waited a day to place the other two blocks back in place. It was an easy rebuild and only a minor setback....bruised ego....
            nobody likes fallen arches!
            back in business
            • #36
              closing in....
              almost done the dome.....it's been interesting with the teardrop shape!
              My son-in-law is in the canvas business so I have a nice tarp to cover the dome while it's resting....
              • #37
                Wow this is going up in record time and looking great!
                Drake
                My Oven Thread:
                • #38
                  rain delay
                  lot's of storms and rain this week...
                  we had 87 MPH winds in Grand Haven on the Mishegame Lakeshore.
                  The oven is now a birdbath!
                  Happy 4th everyone!
                  • #39
                    Glad you had it covered!
                    Mike - Saginaw, MI
                    Picasa Web Album
                    My oven build thread
                    • #40
                      Jim!
                      It's beautiful up here in Northern Michigan - I hope you're getting the same weather. Looks like you can make some good progress this weekend!
                      Chris
                      My oven progress -
                      sigpic
                      • #41
                        Nice weather Christo...so I'm taking the weekend off.
                        I've burned through two diamond saws so I need a new blade to be able to trim the last few bricks and finish the project.
                        Had a nice fire though!
                        Twins too!
                        • #42
                          BenjaMia are cute as buttons! Thanks for the pics!
                          Ken H. - Kentucky
                          42" Pompeii
                          • #43
                            Dome done!
                            Finished the dome..... oh yeah!!!
                            started placing the insulation bricks around the oven before a perlite stucco is applied......then stucco on the outside.....
                            Thinking about the long slow cure method
                            SJ
                            • #44
                              Well done in record time, SJ. So, when's the first annual Michigan Pizza/Bread Bash. I'll make the baguette.
                              CJ
                              • #45
                                Wow! You should go into the business, my friend. Beautiful work, and done in record time. Local builders around here charge 15k-18k for a traditional brick oven!
                                Nikki
