Casting seating wall in Concrete
  • #16
    Re: Casting seating wall in Concrete
    Thanks Francis.
    it is more work that I thought it would be, but with a day or two behind me, I'm liking it better.
    Christo
    My oven progress -
    sigpic
    • #17
      I like it a lot! The glass block is a great touch, especially with it lighted like the picture. I am having trouble "seeing" the whole layout in my mind, though- do you have a plan you could post? The decking on the top of the seat is a nice color, too.
      Elizabeth
      • #18
        I don't have a sketch of the patio handy - I think I cleaned up and it's buried in a pile of papers somewhere.
        I took a panorama shot and took a picture from the deck looking down on one end of the patio. It's a big patio but not huge like the picture implies. The picture should be a large arch - the patio is shaped like a D with the pizza oven at the apex of the arc.
        Last 2 weekends were killer - one weekend devoted to making forms and this past weekend resulted in a pour and some other detail work.
        All in all - 5 columns and 5 benches - next caulk in the glass block and wire up the lighting!!! Then cut and assemble the bench tops. I had planned on the columns acting as planters - but with the glass block I may have to put somekind of cap stone or wooden top.
        Christo
        My oven progress -
        sigpic
        • #19
          The panorama makes it look as big as a football field!
          It looks like a wonderful setup. Are you going to do any acid staining or anything on the concrete? If you end up having to do a cap on the posts, you could always do a potted plant on top of that, and then you'd still have the greenery. I can see some nice ferns there... although I always kill the poor things. If you can't eat it, I tend to ignore it...
          Elizabeth
          • #20
            Cristo,
            Wow, it must take forever to form all that out!I know what you mean about re-using some of the forms for the benches. Sometimes they are a one time thing and don't come off that easy. Looking really good!
            Dave
            Last edited by David Manchester; 09-22-2008, 08:21 PM. Reason: Post read of answer to initial question..I think
            David and Cynthia Manchester
            • #21
              Those are great I have just started building a small retaining wall, but I think I am going to try and make those. Would you please go a little more indepth with making the mold. Thanks for sharing and they do look great! I think you should make the columns out of concrete, to keep the look uniform and the decking would keep it from looking cold and uninviting. cedar would be a nice alternative also, and maintance is not that high with cedar.
              • #22
                Thanks!
                I will dig through some more pics and post them. The benches were poured first and then the columns were poured second. - the form for the benches lasted for the 5 benches and would likely last longer if you leave them on for a day and clean and dry them well after removal.
                The columns were trickier and had some inherent strength issues - The columns overlapped the benches on each end and fit over them like a saddle. The sides that overlapped the front and back of the benches did not have support like the benches, I added 2x4's and after the first pours started to stake them in with rebar. Even then, I had 1/4 inch of spread on one or two of them. No Biggie there.
                The funniest thing that happened (funny now) was on the end column (my second pour). I filled the column form and as I tapped it the level kept getting lower - then I realized the bench was like a piston and was pushing the form away from the bench with every mallet tap. I stopped tapping and when I removed the form the next day the column had moved almost even with the end of the bench - any more and the column form would have separated from the bench.
                It's been a few months now and I'm still very happy with the benches and columns. I'll get the pics posted this week.
                Christo
                My oven progress -
                sigpic
                • #23
                  Here are some of the column form pictures. My wife was out of town that weekend so I used the camera phone.
                  The first pics show the completed form with styrofoam knock outs that I made from laminated 1 inch thick pink house insulation foam. I cut it on my tablesaw (not recommended - I had a piece kick back and scare the crap out of me when it melted a bit and stuck to the blade). from there on out I used either my radial arm saw (another scary tool) and my sander to round the edges. I dressed the edges with duct tape so all faces were smooth. I stuck the pieces to the form with silicone caulk and screws to hold it while it dried. I ran a bead around the blocks and used my finger to create a nice clean radius. it looks great in reverse. I used some trim stock to create a baseboard effect between the two pieces of foam. Its fun to think in the negative space.
                  The silicone caulk separated easily from the form and styrofoam when I removed the forms and I was able to reuse them for all 5 columns.
                  Pic 179 shows one of the forms on it's side getting ready to be put into place. it shows pretty well the amount of bracing I added to the outside of the form. It still needed more based on the flex at the bottom.
                  180 and 181 show the form part way through the pour. I have not inserted the center core at this point. There is a block of styrofoam in the bottom and aftre the concrete was poured above the small arches I put a piece of rebar in and then placed the center core between the two large pink foam knockouts for the glass block.
                  My oven progress -
                  sigpic
                  • #24
                    ok bear with me just a few more pics.
                    183 is the fully poured column with the center core in place.
                    184 is the picture of the end column that tried to extrude its self off of the bench. It shows the lessor amount of bracing the first column forms had.
                    185 is the same column as 184 with most of the bracing removed and inner core removed. - one detail - inner cores - terribly hard to remove onthe benches. For the columns I tried somehting different and cut 1x1x25inch strips of styrofoarm and used these as the corners of the inner core forms. I taped them togheter with masking tape (not duct tape - too hard to separate later) and put spacers inside to keep the shape. removal was very easy. I did not take any pics of these but can make a sketch if you like.
                    186 is what the inside looked like when I removed the inner forms. They flexed a bit but the concrete was so green that it was easy to clean up the inside with a brick used like a sanding block.
                    Hope this helps!
                    Christo
                    My oven progress -
                    sigpic
                    • #25
                      Is your oven built out of block or did you make it like the seats, and how did you built the cabinets around the frigde and stuff Steel and concrete board? It realy looks good, I might have to steal you designs dude, I really like it!!
                      • #26
                        Base is dry stacked block and sides are concrete board and metal studs. Metal studs can differ by the thickness of the metal used - since I'm making concrete countertops I used a heavier guage stud during construction.
                        There are more pics and details at the link below in my signature block.
                        Steal anything you like - I've been doing the same since I've joined!
                        Christo
                        My oven progress -
                        sigpic
                        • #27
                          newbie here.....just getting started and this thread seams dead but it shouldn't be... this is amazing work! love it!
                          thanks for the time in uploading photos on this project...very useful
                          houseofparliament@hotmail.com
                          • #28
                            That is beautiful work!
                            I'm a newbie... love cooking outside, and love working with my hands.... me and my dear wife both decided it's time my two hobbies meet.
                            Oven and outdoor kitchen in my near future.
                            Just starting on ideas... and this one for cast bench supports is superb!!
                            • #29
                              What a fabulous build. Any final photos? Must try some of this
                              Capt. Paul
                              Granite Falls WA, USA.
                              Oven In Granite Falls
