Modern coal oven - Forno Bravo Forum: The Wood-Fired Oven Community
Modern coal oven
  • Modern coal oven
    Anyone ever heard of a modern coal oven? I know the EPA does not allow them any more, however, is there such thing as a catalytic combustor or similar device that can be used on the chimney? There are some coal ovens in New York -but only a few are allowed*-- and they had to be in operation many years before regulations changed. I need to be able to use these in other states in the U.S.
    Also, I'd like to know if anyone is using*wood charcoal (without additives)*in pizza ovens instead of plain wood. Apparently, wood charcoal burns hotter.*
    Thanks,
    Marge
    are some coal ovens in New York -but only a few are allowed -- and
    ### Either Pepe's or Sallies in New Haven uses coal (they were cousins
    and one went coal & one went wood if I recall). Frank Pepe worked for
    Lombardis which is the original home of a brick oven pizza here in the
    U.S. You can put a catalytic combustor on the chimney it's just like a
    normal chimney. It won't do anything because the thing is already
    burning hotter than needed to take care of the emissions. Stoves would
    be a different matter. But, regulators tend not to make such fine
    distinctions so I wouldn't be surprised to find brick ovens tossed in
    with heating appliances from a regulatory standpoint. (Interesting
    note, in CT a brick oven is a food appliance and does not require
    permitting for installing in your backyard...if it were a fireplace it
    would need a permit.)
    > Also, I'd like to know if anyone is using wood charcoal (without
    additives) in pizza ovens instead of plain wood. Apparently, wood
    ### You don't need that in a home oven. Regular oak
    hardwood of between 1.5 & 2 cu ft will give you the 1000F dome temp
    needed to coke the soot off and leave you enough burning coals to cook
    pizza for about an hour. (And then you can cook bread, roasts,
    veggies, etc. on the retained heat. Charcoal might be used in
    commercial ovens but I don't know that for sure.
    Jim
      For Historical reference:
      Both Sallies and Pepe's on Wooster Street in New Haven still use Coal Ovens along with the Spot owned by Frances the grandson of Frank Pepe. Frank Pepe Never worked for Lombardi?s In NY, he worked at a bakery that was located in what was formally known as the Hill Section in New Haven owned by Christopher DeCapua.
        Jim
        Primo
          Charcoal
          We plan to use at least some charcoal in our new oven. It is cheap and a
          by product of the coconut industry. I will let you know how it works after I
          get the oven well seasoned and up and running smoothly.
          JJ
          Philippines
