Oven got wet - Forno Bravo Forum: The Wood-Fired Oven Community
Oven got wet
  • Oven got wet
    I fired it to try to dry it out and just checked it 2 days later and its still damp inside.
    How long does it take your oven to dry out?
    Re: Oven got wet
    What type of roof do you have? Have you checked it for leaks? Do you have insulation blanket and is that wet - may mean leaking roof.
    If I recall, I had to fire the WFO around 5 times to dry it out, but we live in the UK that is always wet
    Good luck.
      Re: Oven got wet
      A lot more fires than you would think. Read the thread on curing in the section "Firing your oven"
