Door closes off chimney - Forno Bravo Forum: The Wood-Fired Oven Community
  • Door closes off chimney
    What a dumb thing to ask. If I close the door to the oven it closes off the chimney.
    To cook then, won't the coals go out and then I would be smoking the stuff? I have looked everywhere for this answer.
    I built my oven from the directions on this site.
    I have chicken in there now but with the door cracked a half inch for air to keep coals going. Well, that is my assumption anyhow.
    Re: Door closes off chimney
    Usually, if you're cooking with stored heat the coals will be cleared out and door closed.
    If you want to cook with live coals/fire you will need to not use the door at all or regulate air flow by placing the door partially open.
    My 34" WFO build
      Here's the page you're looking for:
      Pizza Oven Management | How Wood-Fired Ovens Work
      George has it right: if there's a fire in the oven, you pretty much keep the door off.
        Thank you both very much for your help. I suspect that my oven is not getting hot enough and not holding the heat for very long. It has only been fired 5 times or so.
        I really do need to cook more and get on this forum more.
        Much obliged,
