Hearth Floor Too Hot - Forno Bravo Forum: The Wood-Fired Oven Community
  • Hearth Floor Too Hot
    Looking for some advice. After I pull the coals to one side, the hearth floor is way too hot. I know that I can cool it down by putting a couple of rounds of dough on it. As it is a waste of good dough, I always cringe when I have to do this. I know that I could pull the coals off earlier and let the floor cool naturally. However, I am always pressed for time. Does anyone have any tricks that do not involve the use of dough to cool down the hearth floor? Is there some type of material that I could put down that would absorb a bunch of heat quickly? I know I am likely dreaming here? Any suggestions would be greatly appreciated.
    Re: Hearth Floor Too Hot
    You must learn, "Time Management"! Whatever else you do, is temporary. Once you close the door, in a few minute the oven's going to re-boot back to it saturated state. If its insulated, its doing what it suppose to do.
      You can alway use your indoor oven, when you're pressed.
        Spray some water on it, not a lot, just a couple squirts from a spray bottle.
          Hey Tscar,
          He said, way too hot!!
            If dough is doing the trick for you why not put in a few pans of cold water. That should bleed some heat away in that area for a time...
              I always place the first pizza about halfway in the door where the floor is a bit cooler. Turn more frequently. Then for each subsequent pizza just push it in a little bit further
                I was assuming that he was cooking bread rather than pizza, it that case a little misting and pizza placement can do the trick, especially if he's good in the usage of his peel.
                  Doctor, doctor, ...., it's hurts when I do this.
                  Then don't do that.
                    A damp mop could work for a quick cool down also.
                    Chip
                    Chip
                      cast iron pan with cold water in it
                        I'm with Chip, a damp mop or a damp towel wiped over the surface. I'll sometimes wrap a damp towel over the end of a fire tending tool and then wipe the floor.
                        Chris
                          Chris
                          This works for me too. Sometimes I'll go over the hearth 6-8 times to cool the surface down as much as 100f.
                          ~Aaron
                            Time management and patience is best. I always have an old dough ball from the last time that is the sacraficed pie. Besides how much does your dough ball really costing you? One made with 00 caputo verses bread flour is still not relevant when you look at how much you have into your oven. Finding your rythum is key if you want a excellnet pie.
                              It is not the cost, it is more the supply. Due to refrigeration limitations, we can only produce so much dough at once. Each piece of dough that is sacrificed to the oven gods is one less pie to sell. Taking advice that I received in this thread, I pulled the fire to the side of the hearth about 30 minutes before the event. When I put down the first pizza, I did not burn it. The hearth had cooled enough to allow for a perfect bake. Before, I was pushing the fire to the side only minutes before I started a baking cycle. Thanks to all that help further my education!
