Temperature ratings in wood-fired ovens - Forno Bravo Forum: The Wood-Fired Oven Community
This is a sticky topic.
  • Temperature ratings in wood-fired ovens
    I came across this on the Internet today, and it has me thinking. We need a standard method of describing heat in a wood-fired oven, ranging from warm to very hot. Now that we have finished V1.0 of the Cooking e-Book, I can see that this will help.
    Can we come up with a wood-fired version of this?
    Their "very hot" isn't very hot.
    Conversions
    TEMPERATURES
    Gas Mark 1 = 140C = 275F = Very cool
    Gas Mark 2 = 150C = 300F = Cool
    Gas Mark 3 = 160C = 325F = Warm
    Gas Mark 4 = 180C = 350F = Moderate
    Gas Mark 5 = 190C = 375F = Fairly Hot
    Gas Mark 6 = 200C = 400F = Fairly Hot
    Gas Mark 7 = 210C = 425F = Hot
    Gas Mark 8 = 220C = 450F = Very Hot
    Gas Mark 9 = 240C = 475F = Very Hot
    Re: Temperature ratings in wood-fired ovens
    almost laughable when one is talking about dome temps in the 800's and floor temps between 700 and 750 for cooking pizza.
    Maybe a flat factor (1.71) can be applied to the 425 number to equal 725F
    Mark 1 = 243C = 470F = Very cool
    Mark 2 = 266C = 510F = Cool
    Mark 3 = 293C = 560F = Warm
    Mark 4 = 316C = 600F = Moderate
    Mark 5 = 338C = 640F = Fairly Hot
    Mark 6 = 360C = 680F = Fairly Hot
    Mark 7 = 385C = 725F = Hot - throw the pizza in!
    Mark 8 = 410C = 770F = Very Hot
    Mark 9 = 432C = 810F = Very Hot
    nah looking back at those numbers you should come up with your own scale
      Here is a shot at a wood-fire temperature scale. I would appreciate comments on this -- it's a first cut.
        James,
        Not too shabby for a first cut. I think you have it knocked. Breaking it down further would not add a lot of useful information. Under the "some bread" temp, you might add pan breads, enriched bread, sweet breads or some such.
        Jim
          add in how Mississippi is to be used
          hopefully they won't have a high threshold for pain
            Why do we have to cook at such extreme temperatures, compared to a conventional oven? how is it possible to slow cook.....say a Morrocan tangine at such elevated temps?
            remember i'm learning.
            chicken
              I love the Mississippi's. Kinda says it all like the white dome and how the first couple turn out.
                Hi James!
                Nice idea! I agree, Mississippi's need to be defined. The other useful scale would be flour blackening which is probably useful for 500 to 800 degrees or so. A little experimentation with an IR thermometer should provide a useful column for judging hearth temp.
                Jay
                  Pizza is cooked at blistering temperatures, and a few other things, chicken pieces, chops, shishkebobs, pita breads, that sort of thing.
                  Lower temperature dishes are cooked with retained heat cooking, the fire is shoveled out, the temperatures drop to normal oven temperature, and in go your breads, cakes, roasts, that sort of thing. Later you cook your merangues, your slow simmered dishes.
                  You get the idea. It's a declining temperature curve.
                    And a "Mississippi" is...? I remember it as a counting method, only barely reliable from one person to another depending on their concept of time, especially when someone pronounced it "missippi".
                      Said deliberately, "mississippi" takes a second to say. It's a way of counting seconds.
                        But that isn't even close to clear in James' schedule.
                          Many steak houses using IR broilers up past 800F for grilling. Is this temp range somthing that makes sense in WFOs?
                          Since I'm still in the building stage, please excuse my ignorance if you find it.
                          Chris
                            WFOs do even better than 800. They can do in the 1000 to 1200 range - like Ruth's Chris. You will want to buy or make a Tuscan Grill. You fire the oven just as for pizza but pull the coals to the front of the hearth instead of cleaning the hearth - and put the Tuscan grill in a ways (can get tricky due to the heat! I use a long pair of fireplace tongs). Keep the fire going good. You will have coals about 2 inches below the steaks and the dome should be 1100+. You won't be able to cook a steak over about an inch thick any more than medium rare because it will char first.
                            My favorite way to do steaks!
                            Jay
                              Thanks Texas! I remember a rare lamb loin, chared at about 850F, make that seared rather than chared. Although I also remember many chared rare sirloin baseball cuts.... Oh man!!!
                              Chris
