How Hot is too hot? - Forno Bravo Forum: The Wood-Fired Oven Community
How Hot is too hot?
  • How Hot is too hot?
    How hot is too hot? Well I had this and a few other questions answered last night/this morning:
    sigpic "Why can't you just have a BBQ like normal people?"
    Re: How Hot is too hot?
    After about 8hrs of oven use yesturday, (18 pizzas ,2 calzones and a few other treats) and it goes with out saying lots fo beer. We decided to burn off
    all of our vine and rose cuttings.
    The resuling fire was warm to say the least (for non-UK residents wiki: British understatement) The flames were not just going up the chimney, but coming out the top too (currently about 4-5 foot high):
      After it had all died down, we closed off the oven chamber with a piece of plate steel and went inside.
      This morning (12hrs later), the hearth was ~50?C around the front opening, ~100?C in the centre and the air temp inside was ~50?C.
      So I think a proper door will definately help with the heat retention. Though did notice something slightly amiss with the roof (again refer you to British understatement):
        After taking a few loose tiles off, something seemed to be missing:
          In hmmmm think putting that rafter against the chimney wasn't such a good idea!! Oh well, at least I know the rockwool can stand the heat!
          Well rebuilding the roof will keep me out of misschief!
            Oooops!
            I burnt my pizza peel... but the roof? That has to be a new one...
              Not all of the roof
                If i have the oven fired for around 5-6hours (which keeps a consistent temp of around 400 degrees celcius on the floor) about 15-20 hours later (if the door is left on the contain the heat) i have a floor temp of around 80-100 degrees.
                Regards
                Adrian
                  I think once I have a proper door (ie one that fits and doen't conduct heat) I might be looking at something similar. (well at least 80?C hopefully).
                    Differences in local air temps might play a part too
                      hehe just a bit , although i must admit its getting cold here now and this was done just only 2 weeks ago (winter now).
                      Regards
                      Adrian
