isalation layer - Forno Bravo Forum: The Wood-Fired Oven Community
isalation layer
  • isalation layer
    if the brick dome is on a layer of fire bricks do i need a insalation layer below the fire bricks
    Re: isalation layer
    Yes, insulation under the floor bricks is critical to a successful oven. The free plans offer a lot of good information on this topic; have you found and downloaded them yet?
    Nikki
      Re: isalation layer
      yes i downloaded them but is there a cheaper insalation then perulite and vermiculite because i cant afford it
        Re: isalation layer
        unfortunately, perlite/vermiculite is the cheaper option... but the cost definitely balances out in the long run if you weigh it against the cost of wood in an uninsulated oven.
        -jamie
        My oven build is finally complete!
          Re: isalation layer
          maybe you should build an earthen oven, or is it called a cob oven ? do a forum search, i bet thats the cheapest way you can go
            Re: isalation layer
            how much vermerculit do i need for a 48 by 56 by 3.5 insalation layer
              Re: isalation layer
              (48 x 56 x 3.5) / 1728 in per cu foot = 5.4444 cubic feet. The portland doesn't much change the volume of the vermiculite.
                Re: isalation layer
                so 5 cubic feet of vermiculite sorry new at this so iam a litle mixed up
                  Re: isalation layer
                  will one bag of 90lb portland cement be anuff
