Trying to cool the air space in front of oven - Forno Bravo Forum: The Wood-Fired Oven Community
Burner Tech Support
Forno Bravo has implemented an on line resource for our Commercial Customers to easily access technical information on their ovens.
Included in this section are the following items:
Type 1 Hood Design
FAQ for Burner Support
Wiring Diagram for your control box
Manuals for many of the component parts
Factory Settings for the Omega Control module
Recommended Spare Parts list
Just follow the link below and you can get their. Of course, you can always call in for support during our normal business hours or create a ticket through our on line support email.
http://www.fornobravo.com/support/in...ercial-support
Thanks for participating in our Forum
See more
See less
  • Trying to cool the air space in front of oven
    I own a restaurant with an indoor oven with natural venting only. The oven has a vent toward the front, which works great and no smoke seeps into the room. But, the airspace for about 5 feet in front of the oven gets really hot. Does anyone have any suggestions on a separate vent with a fan that I could install to pull the hot air up and out of the building? Any input is appreciated. Thanks!
    Re: Trying to cool the air space in front of oven
    Sounds to me like you could use a standard roof mounted commercial exhaust fan (typically used for a class 2 hood) or if your building owner would allow just a residential whole house fan in the center of that 5' area. Mounted on the roof ducted to the ceiling with the ridged metal ducting (not flex duct). This will certainly pull the hot air out of the building in that area but its not going to do much for the operator of the oven
    Oh and I wouldn't operate the exhaust fan while initially starting the fire for the days cooking, I would think it would interfear with the draw of the chimney until it gets hot then I'm sure it will be fine. You cant really mess with that area you are talking about because the oven needs air to breath. You have to think of the oven like a fireplace only higher if you start tweaking with the air space in the front of a standard fireplace it throws the whole process off, the natural convection needs to take place inorder for the fire to keep going.
    Good luck
      ^ What he said.
      [/CENTER]
        make sure the exhaust fan has a speed contoller (installed at the switch)....will help "fine tune" conditions
        Damon
        Build #1
        Build #2 (Current)
