Looking for a Pizza oven - Forno Bravo Forum: The Wood-Fired Oven Community
Burner Tech Support
Forno Bravo has implemented an on line resource for our Commercial Customers to easily access technical information on their ovens.
Included in this section are the following items:
Type 1 Hood Design
FAQ for Burner Support
Wiring Diagram for your control box
Manuals for many of the component parts
Factory Settings for the Omega Control module
Recommended Spare Parts list
Just follow the link below and you can get their. Of course, you can always call in for support during our normal business hours or create a ticket through our on line support email.
http://www.fornobravo.com/support/in...ercial-support
Thanks for participating in our Forum
See more
See less
  • Looking for a Pizza oven
    1. Electric
    2. Fast cooker (less than 10 minutes a pizza)
    3. Efficient
    4. Easy to clean
    5. takes little space
    6. high volume
    7. 2 ovens
    I would like to spend less than $5000 on it.
    What would you guys recommend based on the above information? What brands and models?
    Thank you for any replies.
    Re: Looking for a Pizza oven
    I'm afraid that there isn't depth of experience on this forum with electric (or gas, or coal) ovens. Someone may chime in, but it's mostly a wood-fired oven site.
    But ten minutes? You could produce something that looked like a pizza in ten minutes in an plain-old home oven.
      Don't know what you can get in Canada but, here in the US there are two companies Baker's Pride and Blodgett. They both make efficient ovens(electric and gas) that have refractory hearth floors and are available in smaller sizes. I don't know model numbers but they are called "countertop" models(some wood fired pizzerias selling pizza by the slice use them to heat up slices). Most are two deck meaning they have two stone floors each having about five inches of space above the floor. Each deck is usually large enough for one pizza of about 16 inches so I don't think they could be called high volume. Most will heat to about 600 degrees F so there should be no problem in getting you a pizza in much less than 10 minutes, I would say 4 to 5 minutes.
      Best
      Dutch
