Vent exit at dome apex - Forno Bravo Forum: The Wood-Fired Oven Community
  • Vent exit at dome apex
    I'd like to route my vent pipe over the top middle of the dome, over the dome insulation before completely enclosing. My concern is whether using a couple of 45 degree elbows will somehow affect vent flow and its ability to draw efficiently. My oven is 34" and I plan on using 6" pipes. The chimney pipe will be several feet tall to clear the roof line of my home.
    George
    George
    My 34" WFO build
    Re: Vent exit at dome apex
    2 30 degree bends are allowed for fireplace code, I wouldn't do more than that.
      Thanks, I've heard that before but would that yield a vertical vent exit?
      I've been looking at single walled stove pipes and I can only seem to find 45* elbows.
      George
      George
      My 34" WFO build
        Stove pipe is different. I am pretty sure that double or triple wall is the recommendation for ovens. 2 30's set opposite will duplicate whatever angle the pipe enters the first elbow.
          Thanks again.
          Double walled 30* elbows and pipes are way too expensive for what I want to achieve, and especially for the chimney height I need.
          Codes aside, is there any reason why I can't bury a blanket insulated single walled stove pipe under the dome enclosure and use single walled throughout?
          George
          George
          My 34" WFO build
            I think the general concern is that because of the amount of expansion and contraction, you can not get a single walled pipe to seal well. As long as it is all outside and has no penetrations through wood I probably wouldn't worry too much about it (but I still wouldn't go over 30 degrees, you will get extreme build up of flammable soot in 45's).
              With the flue against the dome it should heat quickly and improve draw, which should compensate for the bends.
                Thanks, I hope so...
                George
                George
                My 34" WFO build
                  If it is outside the insulation, it won't warm, but it WILL warm faster because it will have less draw.
                    Ok. What if I used just one elbow as shown in my sketch? I like the single elbow design better.
                    George
                    George
                    My 34" WFO build
                      That should work.
                        Yeah, I too think it will work. I will try these components and see how the set up draws before I enclose the oven.
                        Thanks...George
                        George
                        My 34" WFO build
                          Elbows for stove pipe are adjustable they spin in multiple places to make any angle
                            I realize most do that. I was looking at rigid 1 piece elbows.
                            George
                            George
                            My 34" WFO build
