Chimney OK ?? - Forno Bravo Forum: The Wood-Fired Oven Community
Chimney OK ??
  • Chimney OK ??
    Hi All,
    I have a 36 inch, 3 clay tile segment chimney, it seems to be drawing well with small newspaper only fires. A whisp out the front but no soot buildup.
    Does 36 inch sound too short? I could add another section and the brick is only .30 each.
    Derk
    Re: Chimney OK ??
    My flu is wider then your's, but I only went 24 inches high. If it's drawing well, you are golden. Looking good.
    Les...
      Re: Chimney OK ??
      Thanks Les,
      I just ordered a flue cap and spark arrestor.
      Beautiful brickwork on your oven. I especially like your tool storage. Is that rack an off the shelf garden tool holder setup or a do it yourself project?
      Derk
        Re: Chimney OK ??
        According to me, Building codes require the chimney to be at least 36 inches above the point where the chimney punctuates the roof.
        electric fireplaces
