Forno Bravo Door - Forno Bravo Forum: The Wood-Fired Oven Community
Forno Bravo Door
This is a sticky topic.
  • Forno Bravo Door
    Forno Bravo is gearing up to make a steel front door for Pompeii Oven builders. The door is 19"W x 12"H at the top of the curve, and starts to curve upward at 10"H. This will allow it to work with both flat, lintel-based openings, and curved openings. They are painted black, and have a scrolled handle that holds the door in place to seal closed your oven and holds it upright when it is sitting on a counter.
    They look like the door you see in the Casa graphic here: http://fornobravo.com/residential_pi...izza_oven.html
    Before we have the first batch made, I wanted to double check that this size sounds good to a majority of you. We are having them made by the same company that makes our Cucina oven stand (who luckily is related to someone who works for Forno Bravo), so we know they will come out nice.
    Let me know what you think of the size. They will be in the Forno Bravo Store shortly.
    Looks nice, but not my size. . .
    I need something that is 9 X 18". I think I'll have to make it out of wood with insulation. Getting a good seal will be a challenge.
      Seal
      Fio,
      I made my own door, VERY carefully. However, it still does not seal entirely unless I lean a spare brick against it. Sometimes, simple is good.
      Jim
        Re: Forno Bravo Door
        My door is a cast metal door with twin sliding dampers on the bottom and a peep hole above. It is a commercial variety I believe was made in Spain. I am hoping to use the peep hole to make steam. It has two wooden handles perpendicular to the flat door and two small feet to keep it in place. It mates to a angle iron frame on the oven. I use two small wooden wedges under the feet to keep it in place.
        39 cm wide, 37 cm high....
        I can send pictures in a week when I get my camera if interested.
        Jim
          Oven Door Photo
          Here is the shot of the door to my oven.
            XJ Door
            Okay, now it's painted and I varnished the handles...looks a lot better!
              So is this door supposed to be for the oven itself (meaning behind the vent) or the opening to the vent/landing area. I'm trying to figure out if I should change my oven door opening dimension so that I can use the door there but then I would have to insulate it somehow to make it work.
                Good design and decorative make people attract to u.
                large tote bags
                  Can you purchase the door on its owen?
                  Tony
                    Re: Hebel door?
                    Hello people,
                    Anyone used lightweight concrete (Hebel) to form a door. My current door is a concrete door which I boxed and poured myself. It seals really well and the only reason I'm thinking of another alternative is that the door weighs a ton!!! Hebel panels are around 75mm thick and can be cut and shaped with a diamond blade. They are supposed to have good insulating properties too. Whar do you think? Happy cooking,
                    Geoff
                      Gudday
                      Check out the "Tips" section I have built 2 doors from hebel both of which work well
                      Regards Dave
                        Thanks Dave
                        I'll check it out. Best wishes from sunny Tassie
                          How thick is your Hebel? When I tried it the stuff cracked after a while. This happened twice so I gave up on Hebel. Mine was only one inch thick though.
                            Hi David, I am planning to use the 75mm stuff.
                              Gudday
                              My first temperary door cracked as it was 2 pieces of hedel bolted to 2 x pieces of 10 mm ply ( didn't have one big enough piece of ply). Even cracked I'm still using it a year later in that condition. Mark 11 will be silasticed....no bolts and a little more give between the hebel and the face. A thicker face...less flex between the surfaces.... probably ply with a hardwood face. Finally what if it cracks again...what the heck....its only $8 of hebel....and hardly any effort to carve another. Oh before I forget 75mm (3in) hebel again it stoped the heat in Mk 1 only a little heat marks around the bolt holes... no charing. 75mm will protect the silastic as well.
                              Regards Dave
