stucco against dura vent? - Forno Bravo Forum: The Wood-Fired Oven Community
  • stucco against dura vent?
    I am in the process of doing my stucco enclosure. I plan on attaching metal lath to the decorative arch in the front of the oven opening and then up and around the duravent chimney.
    My question....
    1. What is the recommended way to have the stucco against the duravent chimney?
    Thread: http://www.fornobravo.com/forum/f8/g...land-8759.html
    Member WFOAMBA
    Re: stucco against dura vent?
    Casing bead with a bead of high temp silicone between the duravent and the casing bead.
      I will second the high temp silicone.....it fixed my cracking problem around the Duravent.
      RT
        excuse my ignorance but what is a casing bead?
        My refractory cast oven
        http://www.fornobravo.com/forum/f43/...ven-14201.html
          casing bead - Google Search
          Casing bead appears to be something to protect the vulnerable edge of the cement board.
