CF Blanket and Render - Forno Bravo Forum: The Wood-Fired Oven Community
  • CF Blanket and Render
    Hi,
    I was hoping some advice for the following problem.
    I wrapped my dome in cf blanket yesterday and then coated it with render. I didnt use chicken wire or anything and today when it has dried it has turned kinda brittle and breaks easily when touched. I'm presuming that i will have to take it down and re-lay the blanket using chicken wire?
    Or could i get away with putting another coat of thick render on it to try and bulk it up?
    Cheers Ross
    Re: CF Blanket and Render
    or could i put a coat of concrete on it and would that strenthen it enough?
      Be patient. Someone will answer soon enough. You are so close to being done. I envy you. Good luck.
      Tom
        Chip it off and apply chicken wire first. The blanket isn't a good substrate for a stucco product. The wire gives the stucco something to bind with and also acts as reinforcement. Your final product will be more rigid and you'll get a better finish on it if you go with the wire.
          Why chip it off? it's there already and removing it will just pull off handfulls of insulation. Unless you have a real space problem, I'd just use what's there as a support for your wire armature (hardware cloth is a lot stronger than chicken wire) and move on.
            Good point. The thought of pouring concrete on an bad subtrate sounded not too nifty. I like your idea of putting a stronger lath over it and recoating better than chipping it off.
