trees - Forno Bravo Forum: The Wood-Fired Oven Community
trees
  • trees
    well to continue on with a chimney question? some replys sound like alot of heat will be rising up the flue. living in calif. and having a small backyard my oven is very tightly positioned since it will be close to the house (a couple of inches clearance) i am going to wrap it with fb blanket 3", inclose it and fill the hardi backer with perlite. the chimney needs to be about 6' tall to get the required clearance over the house. but there is a big palm tree about 3-5' from where the chimney will end. please tell me this is ok and i dont have to chop it down.... thanks for all the help
    Re: trees
    Is the palm 3-5' above the top of the chimney or 3-5' laterally from the chimney? You will have heat in excess of 1000F coming out of the chimney but it dissipates fairly quickly. I think a tree 3-5' laterally from the chimney is probably ok. If you have overhanging branches within a few feet you might have problems.
    Ken H. - Kentucky
    42" Pompeii
      Re: trees
      3 to 5 ft is that the horizontal distance or the vertical distance? In other words: if the palm is directly above the chimney I would expect you will experience some issues, if the palm is 5 ft off to one side probably not so much. In still air there is a column of quite hot gas arising from even a baffled cap... that would toast palm fronds. If off to one side probably no problem in still air, and in a breeze the hot gasses are pretty churned up. If the palm is really tall and you are only concerned about the trunk, then it probably is less of an issue.
      If the distance is 3 ft I would expect you would have problems. Although your screen name is Jersey I see you are in San Diego. What is a bad case scenario? Hot weather and dry palm fronds, a small spark and the palm is a torch. Enter the fire department and you get a cease and desist order. No more WFO. (Worst case: you burn down the neighborhood ala' the scene depicted by one of our Auzzie members from a spark from a grinder.)
      I would get your neighbors thoughts on the issue. Even if it isn't an problem for you, if in the mind of a neighbor it is, you have a problem.
      Just my opinion,
      Wiley
        Re: trees
        I have a Queen palm 7' lateral left from my chimney, the palm fronds will hang over the oven and chimney if I let them....I have always kept them trimmed on that side (usually only 1 or 2 fronds) and have had no issues. The good news with the palm is that it has grown about 3' since I built my oven and the fronds don't hang so low any more. Same goes for the oak that is just behind and to the right of the oven, just keep the branches trimmed abount 5' - 6' from the chimney.
        Make sure you have a cap and spark arrestor....I've had a few fires where flames were at the top of my 4' Duratech pipe/cap/arrestor.
        RT
          Re: trees
          Keep a fire extinguisher or water hose handy.
            Re: trees
            Jersey,
            You may want to consider making this portable. Most codes are going to require that the oven be many feet from the house. Could be a problem when you go to sale it.
              Re: trees
              I would hope that anybody with any outdoor cooking apliance would have a fully servicable fire extinguisher within reach of the appliance operating area.
              In fact, I keep a fire extinguisher in reach of every room in the house. That is, door to the furnace room, inside the door to the fish room, top of basement steps, under kitchen sink, beside fireplace, in all closets and of course in the cars.
                Re: trees
                Gentlemen,
                I got one!
                A totally appropriate story about fire extinguishers.
                Once upon a time 'Jack the Knife' {that's me} was a Roofer. 'Jack the Roofer', He was over in Ft. Worth roofing a small flat roof over the kitchen on the back of a 100 year old house near a college. I was torching down 90 Lb rolls of 'Rubberoid' in the summer and I had my old fire extinguisher sitting right there. It came from some old building my Dad had rented and I knew nothing about it.
                The guy who showed me how to apply this kind of roof, to 'torch down' as it were, old Bruce Ruckman, said with great emphisis, "All ways have a water hose hanging from a nearby limb and running! all day! Just a little, but running. If you are going to be 'un Torchero' as the Mexicans say, all ways have water running from that little hose grabbing distance from the roof! First get the people out, then call the fire department, then put out the fire."
                So the first thing I did when I went over there one morning to apply the new roof was to hunt down a water hose that didn't leak. Hoses everywhere and they all leaked but but I picked the best one, no leaks. Found a faucet that worked and hooked up the hose, testing the hose and the faucet. Satisfied, I loaded the roof and went to work.
                I was working along and the roof was almost done and looked pretty good actually, when I turned around and saw smoke coming from inside the wall I was torching on. I tore back the roofing material I had just applied and saw no flame but lots of smoke coming from the back of a board I had been working on. I grabbed the fire extinguisher and it put out a white powder but no liquid. The powder would not go back on the other side of the board where the smoke was coming from. I couldn't get my hand inside the crack and I was starting to get scared. Keeping cool, I climbed down the ladder and went to the front door. A guy opened it a renter and I said:
                "The house is on fire!
                Get everybody and everything out, the dogs, cats, fish, birds, everything, get them out in the front yard and no body leaves so that we can have a good head count. Then go next door and do the same. The renter said she is at work and doesn't have any animals. I said kick in the door, I'll pay for it and make sure everything is out and then you... go back in and call the fire department I'm going to try and put out the fire," and I ran around the side of the house to the back.
                There was no time to waste. I turned the hose on {the faucet was right at the foot of the ladder} climbed up the ladder to the roof and started spraying water behind that board which was still putting out lots of smoke. I could hear fire engines coming in the distance and my old fire extinguisher no good I was in a plain fix! {tap tap tap}
                But the water was helping. The fire trucks were pulling up out front and men were running around the yard. I became aware of a man opposite the wall I was working on and he said: "hey!"
                Hey! I replied and I began to feel better. He said: "You got the fire out!"
                The fire chief and several officers came around the house on the driveway and we were talking when the fireman in the attic or whatever was on the other side of the wall said "here!" And handed me a board about 2" long with a knot on the other side which was scorched. That was the culprit, a 100 year old pine knot. I threw it down to the officers on the ground and they examined it and said: "You did exactly the right thing. You got everybody out of the building and called the fire department, then before we could even get here and we were 2 blocks away, put out the fire."
                "Good work!"
                Yes sir, I said:
                "And when you burn down the building it makes it hard to collect on the job."
                He didn't smile but said kinda to himself still looking down at that scorched board:
                "Roofers."
                Thank you...
                Jack the Knife
