Flue has trouble drawing when it's windy. - Forno Bravo Forum: The Wood-Fired Oven Community
  • Flue has trouble drawing when it's windy.
    Only when it's windy do I have trouble at start-up of the flue won't draw. Anybody have a wind-proof flue cap?
    Re: Flue has trouble drawing when it's windy.
    Hi Iwood,
    I have a supposed wind proof flue cap which is a circular piece of aluminium surrounding the flue cap. I have no doubt that it does prevent some wind from going down the flue. From what I have observed in my oven on windy days is that the wind blows into the oven chamber and disrupts the air flow which allows some smoke to escape out the front. As you said, it happens on windy days mainly on start up. I think due to the fact that on start up there may not be enough heat to have a strong enough draw to fight the gusts of wind that may blow in. Once the fire is roaring though, there?s not much stopping it.
    Cheers,
    Mick
      Never experienced that with my flue and flue chamber which is larger than normal
      My first thought when reading your post was that your flue is too small, probabl6 6" I guess and the chamber thsat catches the smoke and funnels it into the flue is also too small and not performing as it should.
      The only time I have ever had smoke coming out of the front arch was when I was using a leaf blower on full chat to get the fire going with greener wood. Normally if rces the smoke and hot gasses directly up the 12 foot flue.
      Neillís Pompeiii #1
      Neillís kitchen underway
        I had the same problem yesterday, we had some horrible wind blowing from all directions and start up was a bit of a problem but once going it was ok.
        I did notice that there was less of a problem when I had the blast door on and the damper slightly closed to block off part of the flue.
          Wind can't blow into the oven because the oven is partially enclosed and protected. I have an 8" flue and the gases are water-falling down the flue. This occurs mainly at start-up but strong winds can cause the problem, during regular operation, to a lesser degree. Maybe I will just have to live with it.
            Can it blow down the flue though?
            Have you got a pic of the top of the flue?
              Yes, it can blow down the flue. All I have on top of the flue is a conical lid with about 2 3 inches btw the lid and the pipe. No pic
                A pic would tell if there was any obstruction near by that was causing down drafts when windy.
                  Is this your flue?
                  From your facebook page.
                    Ha Ha Brickie...good eye. No that's not my oven flue, it's my fireplace flue and it is way too short, have to lengthen it cause it does the same thing. My oven flue is much taller (3m) and round, but has the same type of cap.
                      That was going to be one of the suggestions.
                      Maybe its the lack of space between the flue and the cap that is restricting the flow?
                      The other thing would be down drafts coming over the top of roofs.
                        Thanks brickie, what about the cap? I'm thinking that some kind of perforated metal or screen in the space btw the flue and cap.
                          If the cap was wider and higher up it would help let the gases out, the surest way to restrict a flue is to have the restriction right at the top.
                            Agreed, will take of the cap and see what happens.
                              let me take a pic of the other flue.
