House Brick Arch - Forno Bravo Forum: The Wood-Fired Oven Community
House Brick Arch
  • House Brick Arch
    Gentlemen,
    Been lurking around here for a bit now and like most others have finally taken the plunge.
    In an effort to blend in with my house and what I am proposing I want to use the same bricks as my house for a veneer around the base block work and the chimney.
    So, the inner arch will be out of firebricks but I am wondering if I can build the outer arch and chimney from extruded house bricks (the ones with holes in them).
    Thoughts and ideas welcomed.
    Cheers,
    vanoontour.
    Re: House Brick Arch
    Not a problem at all.
      Gudday
      Yes I built my entrance way from a mix of brick commons (solids) and house ( extruded with holes). Its been in use for 2 odd years now with no probs and only a very small crack between the inner arch and entrance. Its only on the inside and not external and noticeable. Yes I did use the homebrew mortar on the entrance as well.
      I also used layers of brick on the edge of the stand to caste my top and hide the insulation layer.. you don't need formwork that has to be removed later.
      Regards Dave
