stucco finish question - Forno Bravo Forum: The Wood-Fired Oven Community
  • stucco finish question
    Ok so I got my oven insulated last night and ready to mesh and stucco it now just wondering what mix to use or more to the point should I use a lime mix or just an ordinary Portland mix? I'm going to mix it about 4 to 1 with some sharp sand in the first coat for extra strength.
    I'm unsure as I know the lime will let it breath but as I understand it will let water in as well as out but will have better strength and probably crack less than just cement. Any thoughts? Being in England I want the most water tight finish I can get as there won't be a roof over the oven so I may take some hammer in winter!
    Keith
    my build,
    http://ukwoodfiredovenforum.proboards.com/thread/1209
    my door,
    http://www.fornobravo.com/forum/f17/...oor-21345.html
    Re: stucco finish question
    Being in England, you have access to hydraulic lime, use that and you are GTG.
      Keith,
      If doing a few coats of stucco/render each subsequent coat should be leaner than the previous one. Ie more lime less cement. The brew I use is 4:1:1 silica sand, cement, lime.
