help with chemney - Forno Bravo Forum: The Wood-Fired Oven Community
help with chemney
  • help with chemney
    I have a commercial oven, and the issue is the chimney, is not working, the smoke keeps coming out of the oven entrance any idea?
    Re: help with chemney
    Your flue is to small for the oven. It looks like a 4 inch and should be at least 6 inch.
    Chip
      yup, you?re right, is 4 inch... you`re saying it should be at least 6" that means I should go for 8" wide, right?
        It looks like a corrugated SS chimney liner too. Get rid of that and use a triple wall chimney or box in a traditional clay flue. I realize you are in Mexico and all, but what you have there is a fire hazard.
        Old World Stone & Garden
        John Ruskin
          BTW, are you burning gas and wood in this oven? I was curious about the size of the throat in the vent...that might be hurting your draw too.
          John Ruskin
            That is dryer venting pipe, not flue pipe. Go bigger.
              Holy smokes I think you're right....I just enlarged the images and I missed the sectioning before.
              I really hope that it is really chimney liner and not dryer pipe....wow. Either way, it's gotta go.
              John Ruskin
                Yes indeed, I use with gas and wood, the thoat in the vent is 10" lenght and 6" wide, see atached pictures.
                  ok, Im putting and 8 inch, chimney liner on it, hope it works. THANKS TO ALL YOU GUYS!
                    and, YES, it was a DRYER tube.. LOL, glad I asked.. thanks!
                      The Throat 10" lenght 6" wide
                        In the first pic post number 10 there are two slithers of brick that when removed will aid in the smoke escaping, they appear to be parts of a half brick.
