Chimney question - Forno Bravo Forum: The Wood-Fired Oven Community
Chimney question
  • Chimney question
    I am at a loss when it comes to the chimney. first of all do I need a pipe or a flue or can I just build the chimney from firebricks? I've seen many posts and wesites where no pipe was used, then how does the draw work with a brick chimney/
    Eddie
    Re: Chimney question
    There's no reason why you couldn't build your chimney liner out of firebrick, but refractory flue tile is so cheap that it doesn't make sense to do so.
    You could build an oven without a chimney entirely, but keeping the smoke out of your face while firetending and cooking is an advantage.
      Thank you.
      I am in favor of a flue tile over a pipe, however, one of the reasons I was asking is that I could not get one here in Jacksonville, the brick company that I bought the firebricks from have flue liner bigger than my oven.
      thanks again
