Attaching Insulation - Forno Bravo Forum: The Wood-Fired Oven Community
  • Attaching Insulation
    I got the reccomended ceramic blanket, but I was wondering how everyone anchored the CB to the dome. I know that chicken wire goes over the CB so the stucco/vermiculite/etc has something to adhere to...
    Thanks!
    Re: Attaching Insulation
    Hi Amber,
    I used long 2" clouts (large flat headed nails) hammered just into the mortar joints of my brick Pompeii which held the blanket in place very well. The mortar that I used was a little softer only being a few days old and put hen in without compressing the blanket. High temperature refractory 'adhesive' is a lot harder and may prove more difficult to use. Fine stainless or sharpened nails may be better for this.
    I did not secure the chicken wire but manipulated/folded/crushed it to lay over the blanket.
    If you have a cast dome, then you have a more difficult solution to find.
    Neillís Pompeiii #1
    Neillís kitchen underway
      Amber,
      I wrapped my blanket with bailing wire. I did set in 4 or 5 tapcons at the base to fasten the wire to. You can see it on page 2 of my photos.
      Les...
        Amber,
        I used a couple of tap con screws around the base to hold the wire. I then just wrapped the blanket around the dome and made a few passes of wire. The CB held to the point that I probably didn't need the wire - the cb is pretty rigid. I then wrapped it in chicken wire.
        If you can put a little extra on top!
        Don't forget to wear a mask.
        Good luck
        Dick
          Thanks y'all, that is so helpful!!
