Steel studs
  • #16
    Re: Steel studs
    Originally posted by Ken524 View Post
    In my particular project, luck was involved
    I was afraid you'd say that. I don't seem to have much lately.
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
    • #17
      Re: Steel studs
      Don't worry too much about it, if you hit one just move over. I vaguely remembered the general area of rebar and did not hit one. Unless you really packed them in, the odds are in your favor.
      Wade Lively
      • #18
        Re: Steel studs
        Hey guys, don't mean to hijack this thread but thought you might know. Can you mount a steel track on top of concrete blocks? Between my oven and fireplace I'll be putting in counters which I wanted to build out of steel frame but I need to put a layer of concrete block down first to lift it up and act as a retaining wall. So I'll have a cement slab with a rectangle of cement block and I'm trying to figure out a way to build some steel frame cabinets on top of that.
        Thanks,
        Shay
        Shay - Centerville, MN
        My Outdoor Kitchen/Pompeii WFO Build...
        • #19
          Re: Steel studs
          Sure, use Tapcons to secure them.
          Jim
          • #20
            Re: Steel studs
            Yeah? cool, my main concern was the walls of the blocks would be too thin to drill and screw into from the top vs the side.
            • #21
              Re: Steel studs
              If so, fill the block voids with cement first, then drill into the cement.
              Jim
              • #22
                Re: Steel studs
                DOH! Time for me to put the dunce hat on.. that answer was so obvious it was TOO obvious..
