chimney size - Forno Bravo Forum: The Wood-Fired Oven Community
chimney size
  • chimney size
    I would say either. I have 8" (internal) round steel chimney on my 35
    1/2" oven, and it works great. Though if you want to go with an
    8"x12" clay flue liner that will also work. I did that on my 32x26"
    oven.
    >Dear James,
    >I've come across the following table where on the left are the
    >oven's diameters and on the right their chimney's minimum
    >diameters.
    >Diametro del forno diametro minimo canna fumaria in cm
    >da 60 a 80 cm 20
    >da 80 a 120 cm 25
    >da 120 cm in su 30
    >Our oven is 36" in diameter.
    >Would it be OK to have an 8"x12" flue or an 8" would be
    >better?
    >Thanks,
    >Stanley
