Roofing Tiles - Forno Bravo Forum: The Wood-Fired Oven Community
Roofing Tiles
  • Roofing Tiles
    Does anyone know of a good online source for roofing materials (slate, clay, Itallian tiles)? Right now a I have a composite roof and I want to cover it with something that looks better.
    TIA.
    Re: Roofing Tiles
    Because that stuff is so heavy, your best source is probably the local yellow pages... roofing supply...
    Where is Stilwell?
    JED
      Re: Roofing Tiles
      Stilwell is just southwest of Kansas City.
        Re: Roofing Tiles
        I have all of that stuff, I'm a distributor, but I'm in Michigan. call Spec Building Materials, they are a roofing distributor, headquartered in Kansas City, branches from there to Texas...last number I had was 1-800-821-3204
          Re: Roofing Tiles
          Thanks Stonylake!
            Re: Roofing Tiles
            Thanks, but I googled JJ roofing accessories and all I got was a bunch of hits for a roofing company the UK.
              Re: Roofing Tiles
              kyramary is a signature spam poster. OUT.
                Re: Roofing Tiles
                Gone.
                  Re: Roofing Tiles
                  Try using "Terra cotta roof tiles" as your search terms in Google.
                    Re: Roofing Tiles
                    You can also do the same search in google maps to get more local results. A more general "Roofing suppliers" might generate better leads. You really need a local supplier: this stuff is mostly too heavy to ship. If you do need to get a pallet load shipped, it's much more affordable to get it shipped to a local trucking depot, instead of a domestic liftgate delivery.
                      Re: Roofing Tiles
                      We used clay tiles on our oven roof. Our local roofing company normally stocks clay tiles but they were waiting to order a shipment and they were in no hurry to get it. We looked into ordering tiles online but everyone seems to have a minimum order of 100 field tiles and 25 for speciality tiles. It is possible to use just the fields and cut them with the wet saw to make the ridge caps/end finishers, gable rakes, etc. but drilling holes is a bear. One tile bit does only one tile and takes five minutes. You can of course mortar them in and forget about the drilling. Also, for a pizza oven you will want the short tiles for aesthetics. We ended up scrounging through the local yard and finding enough to get the job done and cutting up the fields where needed. If you can find the mission style half barrels, you can do everything with those. Very frustrating but worth it. Anyway, you can call Ludowici and explain your situation. They may have a dealer nearby or be willing to ship a small order. Ludowici Roof Tile - The World's Finest Clay Roof Tile
                      We used the 13 inch spanish tiles.
                      Dave
                      Album: http://picasaweb.google.com/fornososo/Pizza#
