"Micafil" block fill vermiculite??? - Forno Bravo Forum: The Wood-Fired Oven Community
  • "Micafil" block fill vermiculite???
    I went to my local building supply looking for vermiculite to use as loose insulation over the ceramic fiber blanket I had wrapped around my oven... and they sold me "Micafil" brand block fill vermiculite. It says its for filling concrete blocks or walls and is water resistant. OK- but is it appropriate for the insulating job I bought it for?
    I got it home and poked a hole in one of the bags... it's close to the consistency of oatmeal-like flakes... is that what it's supposed to be? I may have had the wrong impression, but I thought it was supposed to be more granular, larger pieces so there would be air pockets...
    Can anyone tell me whether this vermiculite is appropriate as oven insulation?
    Re: "Micafil" block fill vermiculite???
    It is fine. Perlite is more granular.
      Reassurance is always good...thanks for the reply
      I can't work on it today (too darn cold and the wind's gusting to 60mph), so hopefully tomorrow..
        I often get asked the coverage of a 4 cuft bag of perlite/vermiculite in a CMU wall. The answer, of course, is 16 if the wind isn't blowing.
          Think that i bought the same stuff, but it is called Zonolite. not sure i can use it to mix with Portland cement and use for my Hearth slab. this stuff is almost powdery looks like pepper almost
          Toby
          Columbus, NE
            Originally posted by meco211 View Post
            Think that i bought the same stuff, ...this stuff is almost powdery looks like pepper almost
            Meco211 - not sure what you have, but I don't think it's the same product as mine (although it sounds like it's originally intended for the same purpose)
            As I said in my post - this "Micafil" stuff is almost the consistency of raw rolled oats, not as fine as what you're describing...
              Zonolite is perlite and is fine to use, no matter what consistency.
                Vermiculite is a form of mica. They actually look quite similar.
                  thanks for the response
                  Toby
                  Columbus, NE
                    Vermiculite is EXFOLIATED Mica. That is, it goes through a furnace @ 1000c and the mica expands.
