Used Firebrick - Forno Bravo Forum: The Wood-Fired Oven Community
Used Firebrick
  • Used Firebrick
    I have come across used firebricks for free. Only problem is that the corners are not square. Since I need to cut the firebricks in Half anyways can I use the new cut side facing into the oven so it would look nice and square? I know in the free directions is says to place cut side out. Not sure if this would break down the bricks faster or anything else that might affect the oven. I would still buy new bricks for the oven floor. Thanks for any help you can give as I need to decide if I want the bricks soon!
    Re: Used Firebrick
    shouldn't make a difference in strength... just cosmetic.
      Re: Used Firebrick
      This topic has been discussed previously and the consensus was that the 'factory' finish is really no better than a fresh-cut side. For pictures of an excellent build employing a fresh-cut interior dome see Les' Build.
        Re: Used Firebrick
        Since bricks fire from the outside in, the outside tends to have a harder and more durable surface than the cut interior. In modern brick kilns that difference is minimal, but I'd still use the factory edge if I had it. That said, free is free, and a fresh cut edge would remove any nasties the brick had been exposed to it it's previous life. I'd go for it.
          Re: Used Firebrick
          dlebla
          go for it, with the cut side into the oven. This surface is going to be coated with carbon anyway and after a few uses, who looks at the inside of their oven for aesthetics anyway!
          Neill’s Pompeiii #1
          Neill’s kitchen underway
            Re: Used Firebrick
            I agree...Go for it the bottom half of my oven is made up of used bricks
            Peter
            Member WFO-AMB=WW
              Re: Used Firebrick
              Thanks everyone for responding. I went and got the bricks and some are chipped, but Not that bad. I counted them up and there were 260 full bricks and a few broken ones. I'm going to get new bricks for the floor so I should have more then enough when I start.
                Re: Used Firebrick
                I agree with KraemerBac
                aser tattoo removal
                New Jersey Laser Hair Removal
