S.E. Quensland Suppliers.
  • #31
    Re: S.E. Quensland Suppliers.
    The rockwool blanket was pretty easy to just drape over the dome; I can't comment on rendering over it because I housed it, but there are lots of posts on here describing vermicrete mixes over insulation.
    My Clay Oven build:
    http://www.fornobravo.com/forum/f43/...dah-12821.html
    • #32
      thanks buddy. one other thing have you tried using charchol for the fire instead of fire? im told its better because of the no smoke factor?
      • #33
        I haven't tried charcoal; I use a "top lit" or "upside down" fire. It has a layer of big wood on he bottom, then smaller wood, then smaller again, then the little twigs on top and a couple of fire starters. Once the tinder on top burns a bit there's almost no smoke - works really well.
        Cheers,
        Mick
        My Clay Oven build:
        • #34
          Bagged charcoal is ruinously expensive. Unless you buy the top name brand, it's mostly bituminous coal, which you can buy dollars a ton. It doesn't much smoke (nor does firewood once you get your oven hot) but it does smell nasty.
          • #35
            Hi Every one. I am new here so sorry if I am posting in the wrong section. I was wondering if any one here knew where I could get ball clay in the south East QLD area?
            thanks in advance
            • #36
              For ball clay go to Pottery Supplies in Brisbane, but if you meant fire clay then go to Claypave also in Bris.
              • #37
                that's great, thanks David S!
