Need the ratios for mixing refractory cement - Forno Bravo Forum: The Wood-Fired Oven Community
  • Need the ratios for mixing refractory cement
    I am making my own refractory mortar/cement as described in the Il Forno book using Fire Clay, Portland Cement, Lime, and Sand. I would like to get the ration of materials in the mix.
    Re: Need the ratios for mixing refractory cement
    1 part portland
    3 parts sand
    1 part lime
    1 part fireclay
      This link will really really help you:Cement and Sand Plough Mixing Machine products, buy Cement and Sand Plough Mixing Machine products from alibaba.com when it comes to mixing refractory cement.
      ___________
      Black Granite
        Parts ratio is 3x2x2x0.5, plus water
        3 shovels of the gravel or crushed firebricks
        2 shovels of sand
        2 shovels of the cement
        half shovel of lime ( hydrated lime)
        This amount will require approximately 6-7 liters of water to mix the concrete.
        The website this came from is Refractory concrete mixing recipe | Refractory concrete ingredients for wood ovens.
        You can save much $ mixing your own.
          Originally posted by hb2474 View Post
          1 part portland
          3 parts sand
          1 part lime
          1 part fireclay
          I'm going to use this recipie....Of course, I'll add water
          The mixing instructions at the other link are satisfactory however.
          Lee B.
          DFW area, Texas, USA
