Calcium Silicate Bricks for insulation - Forno Bravo Forum: The Wood-Fired Oven Community
  • Calcium Silicate Bricks for insulation
    Hi All,
    Im after some advice regarding some second hand bricks im thinking of using as my under-floor insulation.
    These are the Calcium Silicate bricks manufactured at Kurnell Sydney over many years, but now no longer manufactured.
    THEY WERE MARKETED UNDER THE TRADING NAME - "CALSIL"
    They are a standard off white colour.
    They are autoclaved sand and cement bricks which are lighter weight yet structurally sound.
    These are the only specs I have on them.
    I've attached a photo of them also.
    Does anyone know if they would be ok to be used for the purpose I have in mind?
    Regards,
    Bruno
    Regards,
    Bruno
    http://www.fornobravo.com/forum/f35/...hen-18538.html
    Re: Calcium Silicate Bricks for insulation
    They will be fine for insulation purposes.
      I though Calsil bricks were house bricks and autoclaved sand and lime?
      I laid some similar back in the 70's.
      http://en.wikipedia.org/wiki/Brick#C...ilicate_bricks
      http://www.schaffer.com.au/about-us/history
        My insulating firebricks actually float in water (they are full of air to insulate)....Do those bricks float?
        Lee B.
        DFW area, Texas, USA
          I havent got my hands on them yet. I'm hoping to pick them up next week so I'll let you know then. I suppose if they are no good as insulators I can always use them as normal bricks somewhere in my stand or bbq bench I'm planning on building.
          Regards,
          Bruno.
          Regards,
          Bruno
            Ok, I picked up the bricks this morning and found that they weigh just as much as a normal brick .
            Does this mean they arent true insulation bricks?
            Regards,
            Bruno.
            Regards,
            Bruno
              Sounds like a house brick to me.
                I'm afraid you may be right Brickie......
                Oh well, i guess they're foing into the bbq bench.
                Regards,
                Bruno
                Regards,
                Bruno
                  They were all the rage back in the 70's, once laid they absorb the pollutants from the air and go yellow.
