dolomitic hydrated spray lime??? - Forno Bravo Forum: The Wood-Fired Oven Community
  • dolomitic hydrated spray lime???
    hey guys
    i have been a member here for a couple of years now and can't say enough good things about the help that people receive ....thank you!
    im building a 36" oven in stirling ontario canada and im having some difficulty finding lime for the "home brew" mix for the dome mortar. i have attatched a photo of about the only lime i seam to be able to find and i'm wondering if anyone can help and tell me if this is type s or n or if this could be used at all???
    i appreciate your time and thank you!
    ryan
    houseofparliament@hotmail.com
    Re: dolomitic hydrated spray lime???
    Originally posted by houseofparliament View Post
    hey guys
    ryan
    Dolomitic has a higher magnesium carbonate percentage than other limestone. You can build with it but..............
    There is a good chance that what you have is type N...and you need to soak it to achieve hydration for workability. Did you buy it at a nursery or Agriculture supply?
    Old World Stone & Garden
    John Ruskin
      It does say hydrated spray lime though. It could be Type S too...finer particle size for spray applications (AG). It should work fine for building.
      EDIT: Just found this..Whitewash Applications | Lime in Building Construction
      You should be good.
      John Ruskin
        I thought dolomite limes were hydraulic?
          Ah stone cutter... Thank you for the reply! I have read many of your posts and have found them very useful. I will contact the company tomorrow and find out directly if it is type s or n and get back to you. Yes.. I bought it at a co-op farm supply.. The guy said that farmers use it on the barn floors to " soak up the moisture"
          I will stay in touch and thanks Again for the reply!!!
            Never mind, I read the lit, it is fine for normal Type S lime use.
              ...and tscarborough...thank you. i will try it out and update the thread for others in my area that would likelt be looking at the same product.
              thanks guys!
              parly
