Fire bricks Spec - Forno Bravo Forum: The Wood-Fired Oven Community
Fire bricks Spec
  • Fire bricks Spec
    hi all,
    I found those Muddox fire bricks at my local masonry shop:
    Alumina: 27.1%
    Silica: 62.9%
    Density: 2.073 g/cm^3 (roughly 129.4 pounds/cubic foot)
    Am I good to go?
    Just for my information, are those considered as Low or Medium duty?
    thanks,
    Serge
    Re: Fire bricks Spec
    Do you get a response how did the Muddox bricks work on your oven?
      The Muddox bricks are good. I used them for the oven.
      I have been using the oven for about 6 months and no issue so far.
        it is good to use fire brick with that specifications for your oven. it is close to high duty
          High duty is 45%>, these are low to medium duty as per the alumina content. They are high in Silica content so I hope you used a mask when cutting.
          Great for the use in ovens.
