Question for Washington State Members - Forno Bravo Forum: The Wood-Fired Oven Community
  • Question for Washington State Members
    I am going to build my permanent oven this year in my back yard I currently have a temporary oven that I built using clay as the mortar.My question is should I have the local Fire Marshall come out and give me the ok to build or should I just build it.Am not sure on what local codes are.Do any of you other Washington builders have any knowledge.Any help or advice would be appreciated.Thanks............
    Re: Question for Washington State Members
    I called the Seattle some-or-other to find out if I needed a permit. They hemmed and hawed a bit, then decided I didn't need a permit. Their primary concern was that it be ten feet from the property line.
    Better call them yourself though. My anecdote won't do you much good in court.
      Thanks...I figured that you need some sore of set back limitations.Will check just to be on the safe side.Thanks
