Question About My Chimney Flue - Forno Bravo Forum: The Wood-Fired Oven Community
  • Question About My Chimney Flue
    I set my flue in place the other day and am debating on whether to surround it with courses of brick or to actually put a mosaic on the flue from some stone that I have left over from covering my kitchen counter tops.
    This stone withstands heat very nicely. I'm always placing a pan right off the stove onto the stone with no problems or concerns. My question is, does the flue have to be separate from anything to allow it to expand?
    I would really like to do this as I think the mosaic would look much better than a traditional chimney look.
    Thanks.
    Journal of My Oven's Progress
    Re: Question About My Chimney Flue
    I insulated and stuccoed my flue. Tiles were put on the suucco. No problem.
      My second oven developed a crack because I used castable refractory around the flue. The xpanding steel flue cracked the castable. I now insulate around the flue before applying the stucco.
        Thanks for the replies. What did you insulate it with?
          I used ceramic blanket wraped in wire mesh then covered with stucco.
