stucco vs percrete - Forno Bravo Forum: The Wood-Fired Oven Community
stucco vs percrete
  • stucco vs percrete
    Luckily I live an hour drive away from FB Marina showroom store in which i had purchased 2 boxes of FB blanket.
    So I used 2 boxes of the FB blanket to insulate my 36" brick dome.
    Its about 4 inches of insulation , now securely wrapped with chicken mesh in an igloo shape.
    This guy at the FB store told me that I can go ahead and use stucco right away to go over FB blanket?
    Or do i mixed perlite and portland cement to go over chicken mesh then apply stucco.
    Any response will be appreciated, thanks
    Re: stucco vs percrete
    I put chicken wire over my blanket, then used vermicrete over that, and put stucco over the vermicrete. I'm dedicated to overkill on the insulation, what can I say!
    You'll have to have some kind of mesh to stucco over if you do it right on the blanket.
    Elizabeth
      I put 3 layers of the FB blanket, chicken wire and put the stucco right over the blanket. With the oven going at pizza temp, my dome is 5 degrees above ambient. If you have 4 inches of the FB you should be fine to stucco right on top.
      Eric
        thank you guys
        i went ahead and apply an 2 inches of perlite and concrete
        then tommorrow apply the stucco
