Barrel Style oven layout question
  • #16
    Re: Barrel Style oven layout question
    My layout is going to be a bit different, but i think it is the same concept. Attached is a picture that shows the layout
    Toby
    Columbus, NE
    • #17
      That is almost exactly how my plans began (with the exception of the angle, I don't like metal in the mix). As I worked through it on paper and stacking bricks, I changed it to what it is now for both simplicity and for strength.
      • #18
        That's Rado Hands design for the Swishy Oven right?
        My 2nd Build:
        Is here
        • #19
          yeah, i am doing mine pretty much like his, but putting a soldier course at the bottom
          Toby
          Columbus, NE
          • #20
            Mitch
            I was looking at your photos of your build and it looks like you used the plans from Radio as well. Are you happy with the oven? I really liked his design
            Toby
            Columbus, NE
            • #21
              Yep - I built the oven for my parents.
              The only changes i would make would be to insulate it better so it doesn't take so long to heat up. (2-3+ hours)
              It really needs more insulation under the floor, and some insulating blanket over the vault roof.
              If you got both sets of plans - in the extra stuff you can see a backyard build where they use some blanket on the vault roof.
              I would definitely do that if i had my time over.
              My 2nd Build:
              Is here
              • #22
                Thanks, i might put more on the top, but since i have already layed the floor and walls i am kinda stuck
                Toby
                Columbus, NE
