oven temp - Forno Bravo Forum: The Wood-Fired Oven Community
oven temp
  • oven temp
    Our oven is finally finished. For curing I have been using a propane torch setup(used for weed burning) and have slowly been heating and cooling. When you speak of "oven temperature" where does this come from. At the setting I'm currently at, I can get temps of 600+ from the dome and mid 300s from the walls and a little less from the floor.
    I have been heating over a 2 week period. Should I continue to slowly crank up the heat to get dome temps of 800+ and floor temps of 500 or am I ready to go?
    Re: oven temp
    Once you don't see any steam coming from the oven, slowly crank it up to 1000F. Let 'er rip.
    Mark
      Re: oven temp
      Let us know how your first pizza works out....Enjoy
      Member WFO-AMB=WW
        Re: oven temp
        Two weeks is more than most, you should be dry. I would think you are ready to go.
        Les...
