kaowol - Forno Bravo Forum: The Wood-Fired Oven Community
kaowol
  • kaowol
    My local supplier here in Canada sells Kaowool for insulation board.
    1- Is it similar to the FB board sold from Forno Bravo?
    2-Is it also good for supporting the weight of the oven
    3- and also is it easy to cut?
    thanks wayne
    Step by Step of Oven #2 Build... I have built this one in partnership with a friend for a customer that took a liking to my first oven https://picasaweb.google.com/waynebe...42PompeiiOven#
    Re: kaowol
    One of our members, Ken, had problems with this stuff. It lost it's rigidity when it got wet, and it's very difficult to build an oven and keep the under-oven insulation completely dry.
    That's the problem, you can see if it sags in the front when it gets wet, it doesn't help the rigidity of the oven.
    They're all easy to cut, with a sawsall or score-and-break. Protect your lungs.
    This said, Ken's oven works, he just wouldn't use the same product again.
      Re: kaowol
      Yep... Don't use Kaowool board under the oven. Turns to MUSH when wet (and you WILL get it wet during the build). You are far better off ordering the right stuff from FB if you can't find a source locally.
      Ken H. - Kentucky
      42" Pompeii
        Re: kaowol
        I would like to get the FB board but as I am in Canada shipping my be too expensive. Waiting for a quote on this from FB.
        When I look locally in the Greater Vancouver area here in Canada I am wondering what I should be looking for. So far all I can find is kaowool and I understand that is not idea so my question is what would the FB board be called if sold under if different name?
        Also as I am building this oven for someone else I don't want to have my order held up at the boarder which is out of Forno Bravo's control. I would feel better if I new I was getting a good product and also from a local source.
        ....thanks wayne
          Re: kaowol
          You can easily cast a slab of insulation using vermicrete. You should be able to access cement and vermiculite locally.
            Re: kaowol
            To continue David S's thoughts... or use perlite in place of vermiculite.
            Hope this helps,
            Wiley
              Re: kaowol
              thanks guys....I used the vermiculite last time and was not too fond of it. I would prefer to go with the board if I can get it localy and I am assured it will not be effected by water.
              I have been told the Generic name for the FB board is Super Isol Board or Calcium Silicate. Can anyone confirm this or give me a feel as to where this I could buy this in Canada........thanks wayne
                Re: kaowol
                The original FB board was cal-sil. It's expensive and a bit of overkill for our current project. I think the current FB board is a mineral fiber board. It's pretty much the same stuff as Kaowool, but with a better, more water resistant binder. The brand I used is insblock19, made by Harbison-Walker.
                  Re: kaowol
                  From the info at the FB store,
                  FB board is made from ceramic fiber, just like kaowool board.
                    Re: kaowol
                    The basic difference is that Kaowool is a Brand name, Isowool is another and, Cerablanket, Pyro-block are all ceramic fiber products. I myself used Isowool ceramic fiber board and blanket for my oven.
