Can I use inulated firebrick? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Can I use inulated firebrick?
    Almost ready to set the oven floor.
    can I use insulated firebrick as the insulator between the oven floor and my cement slab? I did not insulate the slab, its just 6" of concrete.
    Thanks ,
    Ed
    Re: Can I use inulated firebrick?
    You can, but you need about 4" thickness of them if I remember correctly. The insulation value should be about the same as with vermi/perlcrete.
      They will work fine.
