Structural Slab for new WFO
  • #31
    Re: Structural Slab for new WFO
    Thank you Laurentius,
    Your ideas and advice are always greatly appreciated!
    Can hardly wait to fire up the oven. But still a ways down the road.
    • #32
      I attempted the "Easter Island - Head Moving" technique this afternoon using 1/2" PVC water pipe.
      But there is a second issue to overcome: I have to raise the dome section 16" to get it from floor level to the top of structural slab. When using the PVC dowels, I cannot control the weight enough to place additional dowels as you go up the incline. Wow this is heavy! And dangerous!
      The pipe pieces were also starting to chip the brittle casting as it rolled--so really gave up on that because of safety.
      Now it was time to try "The Egyptian Pharaoh - Pyramid Block moving technique".
      This "one man show" operation does not compare to the time in Egypt where there was an almost unlimited supply of skilled and unskilled workers!
      First I fastened a piece of plywood over the brick area--this prevents anything from coming in contact and dislodging their location.
      Next, a plywood ramp (Japan style) 3x6 15mm plywood, with some 2x4's under to strengthen them. This was ramped from floor level to the top of the slab.
      Next, I was able to maneuver a thin sheet of plywood beneath the cast section and with the "lubricant" -- super fine sand. Called "micro tsuna" or micro sand, spread a little on the ramp--jockeyed the block close and was able to pull the casting up the ramp using a rope without a whole lot of effort! The sand acted like "mini ball bearings" but still enough resistance not to slide backwards.
      On top, a little more sand and got it positioned exactly above its final location--but with a layer still separating it from the bricks.
      Now I need to run a long 4x4 through the casting and block each end up. With the aid of a car jack, I can lift it enough to pull the plywood out and lower it to its final position.
      No pulled muscles, or squashed pinkies or toes...So far.
      Probably much better with more people to help, but also a better chance of more people getting hurt.
      I never anticipated the weights that are involved in building a WFO.
      I guess every build runs into the same, but usually block by block/ brick by brick--not these pre-cast masses!
      One down and two to go... sounds like play by play for baseball... Just slower, but more exciting than watching!
      Thank you... all who have commented or checked in... For those of you who have completed one of these ovens....you must have a great feeling of satisfaction. A total brick build really has to test patience and build character.
      • #33
        Mikku,
        Here are some results of a test I did with vermicrete that could be useful for you.
        • #34
          Thank you for the attachment.
          Your data and what I encountered are very similar.
          Mixing quantities- first batch used identical size containers. The bucket measured 6.5 liters.
          5 buckets (10-6 mix) Perlite/vermiculite
          1 bucket portland cement
          6.5 liters water. Had a 4 liter plastic jub that (shochu) - a type of clear alcoholic drink comes in. One full and another market to 2.5 liter level--so always same proportions.
          The pericrete in the plastic bag is still sealed. I assume that setting is like for normal concrete, better to keep moist.. 28 days is a good set but 81 is really a better time for max strength.
          Right, a lot of compressive strength; much lower tensile strength.
          My structural slab form had a layer of plastic on the lower plywood so no absorption downward; greased perimeter forms; and when the pericrete was placed--again covered with a poly sheet (and a bucket of water under the cover sheet to compensate for water absorbed by the first concrete casting.
          It really is funny to work with. It resembles what tile people call "crumbly mud" as a material for doing sloped bases in showers. But that is sand, cement, water---also very dry--but strong.
          Interesting--thanks for sharing your data!
          There is a page about pericrete used for insulated roof decks that listed some of the values for compressive and tensile strengths--alot out there on the web!
          • #35
            How do you survive in Japan, everyone seems so patient and orderly. Yes it is so easy to get impatience when you are on a roll with these ovens but take a deep breath and step back and do it right. You will be glad you did. We did take the Nozomi from Tokyo to Kyoto, zoom zoom.... and the trains are so clean too.
            • #36
              To tell you the truth, sometimes with a lot of difficulty. What appears to be the case is sometimes an illusion. Orderly and conformity are very similar. Creativity is sometimes a byproduct of disorder, or thinking outside the box. A western saying "The squeakie wheel gets greased", An eastern saying "A nail that sticks out, gets hit down!"
              I like to think things through before proceeding, but if every option must be thought through to the nth degree of accuracy...nothing gets accomplished except the actual act of thinking. Sometimes I get caught up in this cycle and that is when the "patience" runs out!
              I once took eight years to completely restore a sports car. Learning all the techniques, measuring--testing to return things to "as built spec's" or Better. Sometimes waiting until a part would show up in Hemmings. When it was finished, it was too beautiful to drive!
              Great results but not the intended outcome! Cars are meant to be driven --not simply looked at like a great painting! I think "balance" is more important but also difficult to achieve!
              • #37
                I am very impressed with your built so far. Truly one of the kind! People at Forno Bravo is getting nervous because your designed is very impressive.
                Who Dat?
                Tu Dat
                If you feel lost with building your WFO, just pray to St. Stephen who is the patron saint of bricklayers.
                • #38
                  Thank you, kind words will get you everywhere!
                  Maybe that should be my nickname- "Mr. One of a kind"! That is the way I feel when going to a shop looking for something, the people probably say "Look out-Here comes "Mr. One of a Kind"!" because I am always looking for something nobody ever orders, so the shopkeeper needs to research it.. If they do finally locate something similar, its always not quite right! Or too expensive--I say-"its on amazon for cheaper BUT amazon is usually too high" that means they are way too high!
                  Forno Bravo must have done a lot of research and prototype building before offering their precasts to the public!
                  IMHO, Nobody in their right mind would use my casting; unless they had easy access to a forklift, unic type boom truck, or a whole lot of help! The weight is excessive for any simple action!
                  So far, I am just winging it. My results may be a very heavy smudge pot?
                  Really believe that there should be a fiber mat below the hearth, but cannot swing the extra $400 right now. (value vs performance?) Probably should have larger interior as well, but our household is only two.
                  If anyone wants to comment on dimensions, please give advice:
                  -750mm inside diameter
                  -445mm height at center of dome
                  -oven opening; 400mmx295mm high with corners clipped 100x100 each way.
                  -transition to chimney outlet size 145x160mm, plan to use 6" round chimney (150mm), initial height 3' (914), probably stainless insulated.
                  -dimension - center of dome to center of chimney (650mm)
                  These dimensions are now "set in stone" or "more accurately AGC CA-13S", but are open to modifications if I had to do again.
                  What is the recommended next layer over the dome (IF) not using ceramic fiber blankets? Something to break any bond? to pericrete?
                  • #39
                    Ran into a snag a couple of days ago, when I altered the firebrick hearth from one that would sit inside to setting the dome on top...had to order a few more brick. Only 6! The shop that I ordered from was happy to take the order, but I did mention that the first bunch was thinner than the size they originally said they were supposed to be.. 61mm/vs 65. I told them it did not matter, EXCEPT, please make sure I get the same again. No communication problem--I heard him talk to the supplier--they said no problem- bla bla. A couple of days later when they arrived. Wrong thickness! 65 instead of 61! The "lady taking the order-swore they were the same!" So trot back to the house, photograph them, e-mail to store, store e-mails to supplier, supplier apologizes and sends a special truck with only 6 brick to the store! Got there at 6:30PM same day!!!
                    Special service! Wow! And I am in no way a big client at this store...just a regular walk-in sometimes customer. But I know the people by sight and everyone gets a chuckle at my rotten attempts at Nihongo- "the Japanese language".
                    So, today was my put things together day. Everything went great! Cut a few brick, this time dry. They were the right thickness-base was level --as is!
                    Did the "Egyptian-Pyramid Block-moving technique" with fine sand and got the other 1/2 dome section (100Kg) 220# set in place. Was able to do so without messing up the brick positions. Had pieces of thicker plywood on top of the brick, thin plywood that the block slid on top, then used a lever (made of wood) to raise the casting enough to get the plywood out. Worked like a charm!
                    I had a chance to communicate with my "special build consultant" for a bit and listened to his words of encouragement and advice. (Always appreciated!)
                    Friday, I received the trowelable castable --so today was also buttering up the joints on the dome??? Who knows if they will hold, but at least the cracks are filled. Even though I wet the dome sections, you could see right away that the water was being sucked out quickly. My hope is that at least a percentage of the trowelable will adhere properly and maybe the pericrete insulation will prevent the patches from falling anywhere when the firing/curing and future using occurs.
                    Lastly, had a little bit of perlite left over from below hearth insulation--so mixed that up 5:1 again to fill in the void between the firebricks and the structural slab.. This brings the outside practically level. This time, I did not have vermiculite to mix in. I do not know why, but the mixing required a lot more water than before. Over 50% more if I calculated correctly. I tried to get it to a consistency that it would retain its shape when squeezed and still not be able to squeeze any water out. What it actually looked like this time---was like a good mix of beach sand and water... suitable for sand castle building.
                    I really do not know how the 10:1 mix will work for dome insulation but probably just a little fluffier. If it is the intent when mixing cement into the perlite for the dome cover to simply provide a measure of adhesion and stability until a render coat can be applied, then probably this next job should be as dry as possible again!
                    Oh! Trouble now. The wife just called down and asked if I am "Still at the keyboard"!
                    Time for a few photos:
                    Sorry if my posts resemble a novel or short story... But just in case someone else right now is facing the same issues..maybe my long explanation can be helpful!
                    • #40
                      Chimney decisions and high costs!
                      Someone once said that you must keep a chimney hot to draft properly.
                      Package stainless steel do just that, but all the parts add up in a real hurry.
                      Made two stops today, sheetmetal shop- friend said stainless steel in .5mm available any length to 15m x 1 meter width. About $30/running meter.
                      Thought of making a chimney.
                      Second stop: metal fabricator: He said, buy ready made spiral pipe SUS304.
                      Says any lengths available-cuts O.K., also flanges, tees, elbows etc.
                      He is checking 150 dia and 200 dia, will know tomorrow.
                      Plan on putting one inside the other, use some spacers to keep centered and fill with pericrete. I think the factory chimneys use a dry fiber but this should work.
                      Anyone have thoughts on this? I am thinking that a one meter chimney, this pattern complete with flange will be around $30. Flange is .8mm (weldable thickness), use a plasma cutter to make the flat base-rest is all .5mm no welds necessary.
                      Once the chimney idea is decided, the rest of the dome insulation can begin.
                      I've searched the threads but so far no advice if there should be a barrier between dome and pericrete??
                      • #41
                        Usually you only need a double thickness insulated chimney if you are going through a roof. Is that so or did you have another reason for wanting it double? It does double the cost and is not worth the expense unless you have a reason IMO. If the expense of stainless is an issue you could consider brick or stone.
                        • #42
                          looks great. Glad you got the dome in place. Sounds like you used the gray matter to find a way of to solve your move. Nice looking set up.
                          • #43
                            First reason-maintain flue temp for good draft. (Something from rocket-stove reading), own experience with soot/creasote build up issues, assumed causes of oven smoking at start-up, die-down cycle.
                            2) Double-wall chimney parts- listed in brochure: (about) $150- starter ring, needs to be adapted to my build, starter collar (same), 6"-thru 4' chimney sections $150-$300, roof flashing, $150 (about), storm flashing, ($30), termination cap ($150-), straps or other supports...+,+ So double-wall is price issue.
                            3) Have not sorted out if "igloo" finish or "enclosing structure", both have advantages. If enclosure, would want double-wall for roof penetration. Want to be covered either way--then can proceed with insulating dome. Right now a roadblock!
                            4) Brick or stone- The seismic region where I live, makes masonry chimneys any height a problem. I asked about "simple flues" the clay type??--simply not available. Also, thinking about working with bricks...puts me in a panic mode...no experience...yikes...something to screw up!!!
                            5) Regular stainless stove pipe is available every home center or hardware store. Used for all burning devices- kerosene, fuel oil, sheetmetal wood burning box stoves. (But soot build-up an issue unless you can keep them hot!)
                            Now that brings us full circle back to (1)!
                            Here is an off the wall question. In the past, I have looked for "masonry cement" here. No one knows what I am talking about? I explain it is used to make mortar more of an adhesive and makes spreading easier. The answer I always get is "we don't know" or they point me to a little package of powder sold in baggie sizes. They say the masons add to portland to do what I am saying! Anyone know what that little baggie might contain??
                            Please "no magic dust!" - that is what they say!
                            Same goes for "lime"- no one knows what it is! But all types of plasters are available! It should be a "stand alone" product and not sold only as a a specialty item. Back -"North" always had it in a bucket in the outhouse at the lake! Had a dipper to toss the stuff over your "job" to keep the flies from gathering!
                            • #44
                              My sheetmetal guy came over later yesterday. He needed something ordered from Italy. He is really into cycling and fashion. There is a new line from Cannondale --their 2013 jerseys etc that he wanted.. Anyway.
                              I was explaining to him "the beautiful work by the architect in Chicago". I mentioned "doh" the Japanese term for copper and - "diamondo" as the shape of the roofing. He immediately started talking how to do it. One thing interesting he said was: You do not need to divide your dome into equal segments--Just lines from pole to equator--spacing not important (only if you want uniformity to piece sizes). If you vary the spacing, you get a more random design. Just need to follow these lines. He said that metal thickness is usually .35mm and up. (.35, .4, .5, .6) all in mm thickness. Thickness over .6 would not be a sheetmetal person's job---changes to a fabricator.
                              I would imagine you would have to follow course lines though...But have not thought of it enough to form an opinion.
                              I thought you might be interested. He also mentioned the pattern name for that roofing design. But I forgot. I can talk to him again when he comes to pick up his jersey in a few days. He usually asks me to order because I can read the english homepage and he does not use credit cards or paypal. Tough to order on line without them.
                              • #45
                                Mikku-sama,
                                I think your problem is that you're not asking the right questions. Everything that need, I had to get for my oven. The person that help me build my oven does not speak English and I do not speak Japanese, but he flip out his iphone and I spelled the word such as "lime" and his translator comes up with a few meaning and we discussed them and problems solved. Do you have a good Eigo-Nihongo-Nihongo-Eigo Dictionary? If not get one to minimize your problems, otherwise you come out as a Baka-gaijin.
