Vermiculite or Perlite - Forno Bravo Forum: The Wood-Fired Oven Community
  • Vermiculite or Perlite
    I'm sure this has already been answered somewhere, but I can't find it so I thought I'd just ask.
    I have a choice of medium grade vermiculite or coarse grade perlite at my local Home Depot. Which would be better?
    I plan on using it to insulate under my over floor and also to insulate over the dome (both as a mix with concrete and loose over the dome).
    Thanks,
    Shannon
    Re: Vermiculite or Perlite
    Perlite on its own is a better insulator, but once mixed with cement there is little difference. I dislike the the fine dust that perlite contains. It is an irritant if you inhale it (wear a mask) never have a problem with vermiculite re this. I can't explain why but if you are mixing with cement a 50/50 mix of perlite and vermiculite makes up a much more workable mix than either of the two alone, particularly if you are making a lean brew.
      Thanks. The Perlite is about $4 less per bag than the Vermiculite for the same size (2cu ft). Didn't know if the coarse texture perlite was better than the medium of the vermiculte, or vice versa. I don't think Home Depot carries it in store for very long each year so I want to go ahead and grab it while I can.
      Shannon
        You may be able to get it cheaper in larger bags (4 cu ft) from nurseries or hydroponics suppliers.
