36" build in Tallahassee - AKA Bruce's Folly
    Re: 36" build in Tallahassee - AKA Bruce's Folly
    Gudday
    Don't mortar you first layer of dome / entrance to the insulation .... Let it float so it will expand and contract without cracking anything.
  • Bec1208
    Originally posted by Bec1208 View Post
    You mean there's supposed to be a plan?
    Let's see,
    Cut off bottom off bottom of door/arch template.
    Mortar sides of insulation
    Begin mortaring sides of perimeter bricks.
    Start next course, then next course , etc...
    Work out thermal break outside inner entry.
    Transition, smoke chamber, and chimney.
    Outer arch.
    Oh, and finish oven door.
    Not necessarily in that order.
    Dave, what did I miss? Bruce
    Oh, yeah
    Lay out ceramic blanket
    Use chicken wire and round out dome.
    Spread render coat to smooth out.
    Waterproof
    And create a vent to let water vapor out of dome without letting water in.
  • Bec1208
    Gudday Bruce
    Now that's starting to look very functionable !! Well done. What's the plan from here?
    Let's see,
    Bruce,
    When you get done trimming the Ca Sil to where you want, take your leftover mortar as you lay your bricks and render the sides of the Ca Sil board. The mortar will keep the Ca Sil from getting damaged, broken, dented while you do your dome.
    Outer arch.
  • Bec1208
    Thanks, it really did come together without much skill or effort. Bruce
  • Greenman
    Hey Bruce - That looks like a prime start to a good door. Very clever using something that is part way there.
