Too Small? - Forno Bravo Forum: The Wood-Fired Oven Community
Too Small?
  • Too Small?
    I poured my foundation yesterday. It's 12' X 40". The size was based on exsisting land marks, esthetics and the need to keep the drive way open to get a trailer past it.
    I am (was?) planning on making the the base stand 48" X 40" and canter-leavering the hearth an additional 8" over the front to give me a 4' square building area. Now I am having concerns that:
    - It is too small of an area for a 36" WFO (or at least adding a vent arch and landing area.
    - The strength of the canter-leaver portion if the hearth.
    Am I over thinking this, or are my concerns legit? I can easily make my base wider. I can also add to my foundation another 12" or so, but that poses many additional challenges. Any and all thoughts are appreciated.
    Re: Too Small?
    BS,
    A 36 inch oven will require more than the 40 you have - a standard build is:
    36 in. interior
    9 in. for the brick (assuming 1 brick cut in half)
    4 in. for insulation (2 in. of blanket - I would think this is minimum for insulation)
    1 in. for stucco.
    The above is for a dome - an enclosure would require even more space.
    The canter-leaver is not a problem if constructed properly.
      Re: Too Small?
      Thank you Les.
      I am planning on a enclosing the oven utilzing a 48" square base. Therefore I know that the insulation around the base will be "thin", as I plan on using 4" X 4" X 16" cinder blocks around it. I figured that as long as the hearth floor is well insulated, as well as the top of the oven, I should be alright. However, it doesn't leave me much room for the arched vented opening and landing.
      How far off am I in my thought process? Is it even doable? If not, what have I not accounted for?
        Re: Too Small?
        Is tied in rebarb enough? I'll probably add some wire mesh just to be on the safe side...
          Re: Too Small?
          Originally posted by Just BS View Post
          Thank you Les.
          Can you post a drawing of what you have in mind?
            Re: Too Small?
            Rebar is fine. Just make sure is goes into the hearth slab a ways and preferably has a bend so there is no chance of it pulling out
              Re: Too Small?
              I'm unable to upload pics from my smartphone. Not sure if its a newbee thing, or a phone thing.
                Re: Too Small?
                The pics are too large and need reducing in size.
                  Re: Too Small?
                  Here is what I started with. It's a 40" X 12' slab, as I am also going to build an off set verticle smoker.
                    Re: Too Small?
                    Once I laid out the first coarse, I realized that there is NO WAY I can do what I want, so I am going to dig another set of footings where the oven stand will be.
                      Re: Too Small?
                      The weather here has cooperated with my work schedule, but once it does, I will include pics of the new forms and foundation.
