Vermiculite or Perlite? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Vermiculite or Perlite?
    Hi, I'm about to start building the heart and I would like to know if is any difference between the two.
    Thanks.
    Re: Vermiculite or Perlite?
    Perlite is a better insulator although once you add cement the difference is marginal. I prefer vermiculite to mix because it mixes up better than perlite and doesn't contain that fine irritating dust that perlite does. I find a 50/50 mix of vermiculite and perlite makes up a more workable mix than either of them alone.
      Thanks!
      I found both in a plant nursery, and I think I will go for a 50/50mix.
        To do the heart, I thought I was supposed to mix the perlite with concrete, now I'm confused
          Cement is the grey powdery stuff. Concrete is a mix of cement, sand and aggregate
            you want portland cement for your mix-Type 1. you can get it at home depot/lowes.
            Mix it in large pans or wheelbarrow at about 6:1 (vemi/per to portland) I will have to look at the water required, but enough to make it sticky like oatmeal is how i did it. HTH
            Texman
            Texman Kitchen
              I found perlite to be half the cost of vermiculite. YMMV
