clearance - Forno Bravo Forum: The Wood-Fired Oven Community
clearance
  • clearance
    How far from a wood framed stucco wall does the oven need to be?
    Re: clearance
    if properly insulated, the oven can be as close as needed. Better check local code in Cali as well.
    Texman
    Texman Kitchen
      Re: clearance
      I had to have my opening 15 ft from any combustable surfaces per local building code. The flue also needs to be 2 ft above roof.
      Chip
        Re: clearance
        Thanks for the reply. I maintained 4 1/2 inche clearance and will fill with insulation.
