Support for brick work? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Support for brick work?
    There is a picture on the 13th page of the 55 pages of pictures in the "residential" set of pictures from Lincolnshire, UK. I wanted to know if there needs to be concrete block behind the brick hearth stand(where the wood is stored)?
    Thanks for a reply.
    Mike
    Re: Support for brick work?
    can you copy/past the pic so we can see which one you are referring to?
    Laziness...
    Texman Kitchen
      I plan on building the stand and oven, not the flanking work stations. Does the stand need to have cinder block support under the brick or not?
        Pizza Oven Photo Lincolnshire, UK I would say yes....can't say for sure...
          A little confused here. If you are building the stand, what are you planning on if it's not block? Are you building it out of iron?
            if i understand the ?- properly laid brick will support the stand, no need for cinder block underneath. Most builders use the cinder block because it is easy to set and then add a brick veneer or stucco for appearance. But, a stand made of brick is fine if done correctly. Reach out to the brickies on the site. Ask Al - brickie in Oz.
            Tex
            Texman Kitchen
