Pizza oven new build- need suggestions - Forno Bravo Forum: The Wood-Fired Oven Community
  • Pizza oven new build- need suggestions
    Hello everyone
    Im going to build a mobile pizza oven and need some suggestions.
    here is a couple photos of what im building..
    2013-10-08_1012 - BIGBOB1's library
    2013-10-08_1011 - BIGBOB1's library
    I live near a National Refractory supplier so I can get anything from them.
    The base I was looking at a using a wood mold that would be 2-3 inches high to fill the base. The first layer would be 1 inch or so INSULATED refractory cement. Then follow with mid to high temp fire bricks on top.
    For the Pizza Oven I was going to use refractory cement on the first coat then the second use insulated refractory cement then refractory cement to finish top. ?????
    would I need chicken wire in-between layers?
    any suggestions I would appreciate???
    would you use the medium or high rated fire bricks?
    Re: Pizza oven new build- need suggestions
    I will also be using sand as the mold for dome....?????
