Starting a Wood fired pizza restaurant..Help needed - Forno Bravo Forum: The Wood-Fired Oven Community
  • Starting a Wood fired pizza restaurant..Help needed
    Dear All
    I have been following fornobravo for the last one year and got to know lot of useful information.
    Let me tell about myself. I am techie working in Hyderbad (India).
    I always wanted to start a italian pizza restaurant in Hyderbad and after going through lot of information in forno bravo I decided to install wood fired oven.
    I really thank you all for your great posts. I need your valuable suggestions for the next few weeks.
    I already acquired a property on lease couple of days back. I will get two months rent free period before which I need to furnish my restaurant in every aspect.
    The property is on ground floor and the building consists of 5 floors and 2 basements for car park.
    to begin with I started to explore for firebricks, insulation etc..locally for the 42" build. Here is my find
    I found 40% alumina firebricks that will cost me around 50 cents each. I see insulating blanket measuring 1"X24"X84" priced at 20$.
    Here are my initial set of questions. I need your help in getting the following things clarified
    1. As the property is on first floor do I need to still go with stand construction with rebars inserted into the cement blocks..or Just brick is okay wih out rebars?
    2. I am not sure whether the blanket mentioned in the below link is same as the one desired.
    Superwool Industrial Insulation | Commercial Insulation Products. AES Fiber Fibre
    3. Can I replace vermiculite concrete insulation under the hearth with just calcium silicate boards.
    Thanks in advance. Waiting for your valuable advice.
    Re: Starting a Wood fired pizza restaurant..Help needed
    1. Check to make sure the floor is strong enough to take the oven. A 42" is really heavy. I think you should use the rebar.
    2. That's the right stuff. Your prices on refractory materials are great, I wish I could get stuff that cheap.
    3. Calcium silicate board would be much better than vermiculite concrete and quite suitable.
    Check out strivers build, he is also in India with a commercial restaurant.
      Thank you David
      I will go with rebars and cal sil boards with out vermiculite concrete for the hearth.
      I will start the build with in two weeks and will upload the photos here.
