Concrete Calculations - Forno Bravo Forum: The Wood-Fired Oven Community
  • Concrete Calculations
    Hi folks,
    I'm trying to work out the weight/volume of ingredients I'd need for a given volume of concrete. I presume the volume of concrete you end up with is not the combined volume of the ingredients?
    Edit:
    I know the volume of the casts...
    Do I just assume a certain density for the finished concrete and thus calculate the finished weight and then assume that the combined weight of the ingredients should equal this weight?
    My oven on a pallet build thread
    Re: Concrete Calculations
    The final volume is not the combined volumes of the ingredients, but the mass IS the combined mass.
    Are you talking regular concrete or refractory castable?
      I'm not sure what I'm talking about yet... I'm trying to get an idea of how much of what I'd need for the various options... since I'm going for a small oven, I don't think the cost difference will be much.
      I would probably go with a refractory castable if I could find one here in France. Identification and availability of the materials may determine what I use in the end. I am currently looking at a mix of sand, clay, ciment fondu and crushed brick. I've read good things about this mix in France... assuming I can overcome the fast set time issue. Since it is a small build, I might get away with it if I have extra hands.
      So I guess I just need an idea of the resultant concrete's density, then I can work out the final weight and thus the weight of the individual components I need.
        Originally posted by di11on View Post
        Hi folks,
        Edit:
        Wet volume is approximately 80% of the dry material
          Thanks for that - using that formula says I need about 10% more than using my assumed density formula - I hadn't account for any error, so that gives a good number to work with.
            The density of castable refractory also varies depending on brands and what type you get. Go for dense castable not insulating castable for the inner dome. The stuff I use is approx 2 Kg/litre or quoted as 2000 Kg/m3 Check the specs on the stuff you are getting.
              Hmm... I was gonna go with this stuff... CIMENT FONDU? but it says it has a bulk density of 1100kg/m3
                Just looking into this a bit more...
                In most of the forums I've read that you multiply the desired volume by 1.54 (or 1.64 if allowing for 10% wastage). But I guess this is for regular portland based concrete. 80% as you quote would be equivalent to multiplying your desired volume by 1.25 which is quite a bit lower. Is the 80% figure specific to refractory cement?
                My calculations show that I will need just less than or just more than one 50kg bag of grog (depending on which calculation you go with), so I'm wondering if I need to get a second 50kg bag or not (costing me an extra €75). What would the impact be of less grog and more sand? Less thermal mass? Weaker structure? At the same time, an advantage of getting a second bag of grog is that I would get a different granularity giving me a better distribution.
                Thanks in advance
                  When I mixed concrete in a mixer on site rather then ready mixed the accepted ratio was 21= 18 which is about 85% or a 15% reduction this mix has aggregate so the mixing of a brew with more fine aggregate May result in less volume.
                  My experience is that more material is consumed by wastage and additional volume then measured , having poured many concrete slabs experience is that you always use more then the theoretical calculation so be conservative
                    Calculate the volume of your dome (using outside radius to calculate total volume, subtract inside volume using inside radius) get the volume required, but don't forget to halve this because it's a hemisphere, then add the 20% for reduction on mixing. The extra required where the oven door sticks out at the top will be about the same as what you lose in the actual door opening.if you also want to cast an entry you'll need more castable for this too.
                      Hi folks,
                      So I've actually cast the first of 4 sections of my dome. Everything going well so far. I used iced water and had plenty of time to work with the mix. The batch I prepared left me a little short by 1 to 1.5 cm of thickness (I was shooting for 7cm). Is there any problem with adding another layer? If so, do I need to wait until the previous layer has set? I presume I would need to use the same mix?
                        You can add on another layer straight away, but it won't be as good as if if it were cast in one go. The other alternative is to leave the casting as it is and thicken it up when the oven castings are all assembled.
                          Thanks David. When you say thicken it up one assembled, won't I risk cracking if I cover over the assembled sections?
                            Ok, so I've cast my dome... using a ciment fondu/grog/sand mix. Just waiting for the last section to cure.
                            What's the deal with curing fires? Do they just speed things up, or do they lead to better strength/performance?
                              By casting your dome in sections you are telling it where you want the expansion stresses to occur. If you cover over the dome with another layer any expansion cracking will take place where you have designed it, rather like grooves in a concrete slab.
                              Re driving out the water, firstly, did you add any burn out fibres to your home made castable? If not then you will need to proceed extremely slowly. Recommended firing schedules for commercial castles (that do include burn out fibres) are in the range of 25 to 50 C /hr Particularly for the 100- 300 C range where steam explosions are most likely to occur. The temperature of the castable will vary wildly between the top of the dome and the base as the base is way wetter and cooler. You can't take it too slowly, but you certainly can take it too fast. If you are having fine weather then leave it exposed to the sun and wind for a couple of weeks to do much of the drying for you. It's a bit like trying to fire a clay pot that hasn't dried. It can be done, but is way more risky.
                              The firing will not add extra strength to your castable unless you fire it to around 1000 C. Do not attempt to do this as rapid chemical changes take place around 550 C that can damage the refractory and firing with wood is impossible to control in a slow enough temperature rise to do this safely at this range.Your mix should perform ok, but will never be truly sintered.
